Newb question. Please help.
Old Mar 8, 2006 | 05:25 PM
aesthetics82's Avatar
Default Can I weld an iron nut to an aluinum plate? Newb Question
I need to install the temp sensor for my water temp gauge and I have a galvanized iron nut that I need to weld onto an aluminum plate. I am going to drill out a hole in the aluminum plate and weld on the nut so I can screw the temp sensor in. Can I weld the iron nut to the aluminum plate or is there another way to attach it? Can I stick weld it on? Im taking a welding class and so far we are only doing stick welding. Which electrode would work the best (if any)? 6010, 6013, 7024, 7018, 6011? Thanks.
-RJ
Modified by aesthetics82 at 11:36 AM 3/9/2006
Old Mar 9, 2006 | 10:36 AM
Default Re: Newb question. Please help. (aesthetics82)
anyone?
Old Mar 10, 2006 | 12:44 PM
MajorPayne's Avatar
you cant weld iron or steel to aluminum, your best bet would be to find an aluminum bung that is the correct size for your sensor and weld that on...or i suppose you could try jb welding it on if you dont want to go that route, but i consider jb welding stuff kinda "half-assing" things, unless theres no other option, which most times there is
Old Mar 11, 2006 | 12:18 PM
Since I can't weld the nut on is there a way that I can drill out the correct thread in the aluminum plate. I think its 1/8npt.
Old Mar 12, 2006 | 07:50 AM
MajorPayne's Avatar
Default Re: (aesthetics82)
how thick is the plate?
Old Mar 12, 2006 | 03:23 PM
dfoxengr's Avatar
Default Re: (MajorPayne)
i would get and Al nut.
Old Mar 12, 2006 | 04:40 PM
stealth-wrx's Avatar
I have 1/8 npt aluminum weld bungs. You can get them from mcmaster carr.
Old Mar 13, 2006 | 03:54 PM
The plate is 1/4 in.
What is an Al nut?
Old Mar 13, 2006 | 04:01 PM
ManBearPig4silly's Avatar
AL nut = aluminum nut.
jetspeedz
Oct 3, 2014 11:09 AM
96integraLS
Jan 6, 2005 06:55 AM
Sohc Driver
Jun 9, 2004 07:05 PM
fuguman
Aug 2, 2002 01:58 PM
JM Performance
Mar 25, 2002 10:27 PM
