95 gsr into 92 4dr civic
Old Mar 6, 2006 | 06:04 AM
CivicGStypR's Avatar
Default 95 gsr into 92 4dr civic help!!
I need to know what all I need to make this happen. I already have everythging from my gsr but dont know about my shift linkage fitting or what all I am going to need to finish the swap!!???
Modified by CivicGStypR at 7:31 AM 3/6/2006
Old Mar 6, 2006 | 06:23 AM
dennis278's Avatar
i believe you need the motor mounts that come on the gsr engine, you'll have to wire up the vtec your self, you must run two wires from your ecu to your engine you can search for exactly how to do this. For the shift linkage, i think it will just bolt up.
Old Mar 6, 2006 | 06:24 AM
civexturbo's Avatar
Make sure you get the rear engine mount, the wire harness, and the **** linkage, the ecu, and the axles from the GS-R. There are a lot of more detailed threads on the topic and some books with swap info in them. Have fun with it.
Old Mar 6, 2006 | 06:36 AM
Oh yeah I almost forgot. It's a auto right now. thats why i asked about the linkage.
Old Mar 6, 2006 | 06:45 AM
usdmEHboy's Avatar
Default Re: 95 gsr into 92 4dr civic help!! (CivicGStypR)
you can find soo much useful info here
https://honda-tech.com/zerothread?id=642479
Old Mar 6, 2006 | 06:46 AM
zacatkings's Avatar
Default Re: 95 gsr into 92 4dr civic help!! (usdmEFboy)
92 pre wired for vtec from factory from firewall to ecu. just need to get si/ex engine harness and chipped p28 good to go
Old Mar 6, 2006 | 06:54 AM
biggnutz123's Avatar
yull need integra motor mounts or hasport ect. ummm.. yull need the shift linkage also from yur integra well if i forgot anything forgive me it early in the morning were i live.
Old Mar 6, 2006 | 07:09 AM
I have the gsr harness and the ecu, so i dont have to wire vtec at all?? just plug everything in and it should work? I also have all the monts from the gsr so im good huh.. what about the shift linkage the gsr should bolt right up??
Old Mar 6, 2006 | 10:21 AM
need more info come on.....................
Old Mar 6, 2006 | 11:16 AM
FalkenSiR's Avatar
Default Re: (CivicGStypR)
search come on... you are asking the most often asked question.
halocore
16
Jul 31, 2008 09:50 PM
mrod1985
Feb 18, 2008 02:25 PM
rough_draft
Mar 21, 2005 08:43 AM
WhtHatchBack
Mar 9, 2005 08:01 PM
cyfiro
Mar 31, 2002 11:24 PM
