gt2540r for my D
Old Mar 5, 2006 | 09:04 PM
turboeg77's Avatar
Default gt2540r for my D
has anyones used this turbo on a D series before.
http://www.japaneseperformance....html
il be getting mine next week and im planning to put it in my D for my build. goal is to make 350ish whp will this turbo be worth it. ive only seen the SR20 guys using it.
Old Mar 5, 2006 | 09:10 PM
Muckman's Avatar
Moderator in Chief
Default Re: gt2540r for my D (turboeg77)
how big is the compressor wheel?
Old Mar 5, 2006 | 09:21 PM
turboeg77's Avatar
Default Re: gt2540r for my D (Muckman)
comp. wheel 60mm 60trim
comp. housing .70ar
turbine wheel 53mm
turbine housing .86ar
Old Mar 5, 2006 | 09:33 PM
HiProfile's Avatar
I think 350ish would reealy be pushing it with that one, esp on a d-series. Why? Lower rev capibility of d-series coupled with the turbing squeezing upper-rpm exhaust flow quite a lot. However I have no doubt it could produce a very big torque number (which is why seeing it on sr20's makes sense - those guys love spooling *off idle*). I think this would be an excellent turbo if you run around town with slicks. I'm unsure of the exchange rate, but I'd guess you could get a gt28rs for not much more, if not less.
Old Mar 5, 2006 | 10:14 PM
GiNuWiNe's Avatar
Default Re: gt2540r for my D (HiProfile)
the gt28rs is only rated to 350bhp that's rated to 440bhp i believe.
Old Mar 7, 2006 | 06:02 AM
turboeg77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I think 350ish would reealy be pushing it with that one, esp on a d-series. Why? Lower rev capibility of d-series coupled with the turbing squeezing upper-rpm exhaust flow quite a lot. However I have no doubt it could produce a very big torque number (which is why seeing it on sr20's makes sense - those guys love spooling *off idle*). I think this would be an excellent turbo if you run around town with slicks. I'm unsure of the exchange rate, but I'd guess you could get a gt28rs for not much more, if not less.</TD></TR></TABLE>
i really dont get your point. if you would look at the numbers on this turbo it was rated by garrett to make 420hp where as the gt28rs is only rated at 350hp. so why would i be making big torque and no power on this turbo? im assuming that it would make more power than the RS. and ive riden a car with a gt2871 which is bigger than an RS and I was looking for something more after that.
Old Mar 7, 2006 | 08:02 AM
GiNuWiNe's Avatar
i believe he confused the gt3240 with the gt25r, cause the turbo your thinking about getting power rating is a good 80hp more than what the gt28rs is capable of. I say good choice of a turbo for your goals, maybe even go with the gt3037r.
Modified by GiNuWiNe at 12:03 AM 3/9/2006
Old Mar 7, 2006 | 06:52 PM
turboeg77's Avatar
Default Re: gt2540r for my D (GiNuWiNe)
i did think he had himself confused. anyway my gt2540r is arriving today. i was also looking at the 3037 before but my supplier dosent have it on stock. anyway thanks for the advice.
DUB20VT
Mar 11, 2005 06:56 AM
DUB20VT
Feb 2, 2005 02:33 AM
stizzit
Sep 6, 2004 07:20 PM
94sohcEx
Apr 5, 2004 03:40 PM
