specs of turbo?
Old Feb 20, 2004 | 04:31 PM
94sohcEx's Avatar
Default specs of turbo?
anyway of finding out what the specs on a turbo are? (i.e. trim, a/r) is it marked on the turbo housing? or do you just have to be seasoned boostologist? thanks
Old Feb 20, 2004 | 04:44 PM
b16ahybrid's Avatar
Default Re: specs of turbo? (94sohcEx)
the numbers should be on the housing
.48 .42, .63 etc
Old Feb 20, 2004 | 04:49 PM
94sohcEx's Avatar
Default Re: specs of turbo? (b16ahybrid)
lots of numbers but nothing close or anything that makes sense. sorry im new to this ****.
Old Feb 20, 2004 | 05:46 PM
alpha's Avatar
If you want to identify the trim of the wheels you take the housings off. After that with dial calipers measure the base of the wheel then the "tip" of the wheel. These measurements measurements will fall into the proper equation to find the trim size below.
compressor wheel:
(inducer * inducer) / (exducer * exducer) (100)
turbine wheel:
(exducer * exducer) / (inducer * inducer) (100)
Old Apr 5, 2004 | 02:28 PM
Matgallis's Avatar
Default Re: specs of turbo? (0x64)
what?
Old Apr 5, 2004 | 02:42 PM
PrecisionH23a's Avatar
If you look at the exhaust flnge on the turbo there should be 2 numbers stamped the sides. One on the exhaust side and one on the compressor side.
Give those numbers in relation to the sides and we can figure it out for you. Usually there will be numbers also stamped on the compressor housing and exhaust housing such as 60 A/R and .48 A/R.
Old Apr 5, 2004 | 03:40 PM
TravSi's Avatar
I love that formula, its so fun to say out loud....
miamihonda
Feb 12, 2015 02:00 AM
civic92si
Sep 19, 2010 01:36 PM
DUB20VT
Mar 11, 2005 06:56 AM
Acura_I-RS
Feb 23, 2003 06:41 PM
