Which manifold will make more power down low? Blox or Neukin?
Like the title says, im thinking of getting a new exhuast manifold soon since im getting a custom downpipe made. i currently run the drag manifold. This is a daily driver with 12 psi max. I start building boost by 2500 rpm then it gets to about 4 psi or so and then slowly gets to 12 psi by about 5500 rpm.
setup is b16 block, gsr head, cosmetic headgasket, arp headstuds,
T3T4 E turbonetics turbo 440cc injectors hondata s200, Edelbrock IM etc
Looking at my dyno I see that the TQ Curve and the HP Curve meet at about 5200, i dont know if that is relevent to the topic but can someone tell me if i would benefit more from a BLOX or a NEUKIN? ive heard that Log ones are better than ramhorn. I want more midrange than top end, becuase top end isnt a problem with me. I have more to say , but ill just wait to see the posts. Thanks
ramhorns are much better than logs, as for the torque crossing over at 5250 rpm, it will always do that, horsepower is a function of torque where they will always cross at 5250 rpm, just an FYI. IMO get the ramhorn manifold, its much better overall
From log to ramhorn, I picked up almost 100ft lbs of tourqe at same boost level.
Only other things changed were 2.5 downpipe to 3 and also an LS crank.
keep in mind that i run low boost levels, 12 psi max. Just talked to my tuner he recommends i get the blox for bang for buck. Im getting a custom DP too and a 3 inch thermal exhuast system
DELshaneSOL
Jan 24, 2012 06:50 PM
