wastegate vacuum?
Hey guys i am installing my first turbo setup on my car and i have a quick question... it has an external wastegate setup and there are two threaded holes on the wastegate... one on the side and one on top... my buddy had a vacuum line connected to the side of his wastegate and a screw on the top but mine didnt come with a screw for the top... what do i need to do? thanks a lot
-Josh
-Josh
ok right now i have the sid hooked up to the compressor housing... and if i want a mbc i just put it inline somewhere between them correct? what is the top port for? thanks for all the help
-Josh
-Josh
The top port is for using an electronic boost controler. If you use a manual, you just install it inline between your pressure source and your side wastegate port just like you said.
Killer_B
Oct 5, 2003 09:06 PM
GeorgeJetson
Jun 12, 2003 12:58 PM
