wastegate vacuum?
Old Feb 6, 2006 | 06:27 AM
Crimson_Tide's Avatar
Default wastegate vacuum?
Hey guys i am installing my first turbo setup on my car and i have a quick question... it has an external wastegate setup and there are two threaded holes on the wastegate... one on the side and one on top... my buddy had a vacuum line connected to the side of his wastegate and a screw on the top but mine didnt come with a screw for the top... what do i need to do? thanks a lot
-Josh
Old Feb 6, 2006 | 06:42 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: wastegate vacuum? (Crimson_Tide)
hook the one on the side up to a source of manifold vacuum, or the snail as i like to do, and leave the top open.
Old Feb 6, 2006 | 07:05 AM
Default Re: wastegate vacuum? (boostedcivicsir)
ok right now i have the sid hooked up to the compressor housing... and if i want a mbc i just put it inline somewhere between them correct? what is the top port for? thanks for all the help
-Josh
Old Feb 6, 2006 | 08:06 AM
Jay_Sensing's Avatar
The top port is for using an electronic boost controler. If you use a manual, you just install it inline between your pressure source and your side wastegate port just like you said.
Old Feb 6, 2006 | 10:35 AM
Default Re: (Jay_Sensing)
awesome guys... thanks for all the help
-Josh
ef dino
Sep 16, 2007 10:21 PM
88rexHF
Sep 22, 2004 08:13 AM
jwcardy
Sep 5, 2004 02:06 PM
Killer_B
Oct 5, 2003 09:06 PM
GeorgeJetson
Jun 12, 2003 12:58 PM
