What can happen if you drive your car and your wastegate is not all the way shut?
Old Feb 5, 2006 | 06:15 AM
JUST2SPOOL's Avatar
I AM A SCAMMER, DO NOT BUY ANYTHING FROM ME.
Default What can happen if you drive your car and your wastegate is not all the way shut?
I need to know all the bad con's..
Like will the turbo over boost or spin harder becasue it hasnt reacched its peak yet.
Old Feb 5, 2006 | 06:48 AM
AbitAvenger's Avatar
i dont think you will make much boost...
Old Feb 5, 2006 | 06:54 AM
B18 CYA's Avatar
if wastegate is open you will be losing boost
Old Feb 5, 2006 | 07:03 AM
N20civicB18's Avatar
Default Re: (B18 CYA)
technically you wont be loosing boost because it wont ever make that boost it could of been making. you should be fine driving it, you'll just have boost lag
Old Feb 5, 2006 | 07:39 AM
coneheadsracing's Avatar
Default Re: What can happen if you drive your car and your wastegate is not all the way shut? (JUST2SPOOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUST2SPOOL &raquo;</TD></TR><TR><TD CLASS="quote">Like will the turbo over boost or spin harder becasue it hasnt reacched its peak yet.</TD></TR></TABLE> I wondered this also, and i'm thinking it would. Whether it is out of the range of the turbo i don't know, depends on how much exhuast you can push to it, and the size of the turbo.
Old Feb 5, 2006 | 07:58 AM
MidShipCivic's Avatar
Default Re: What can happen if you drive your car and your wastegate is not all the way shut? (coneheadsraci
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote"> I wondered this also, and i'm thinking it would. Whether it is out of the range of the turbo i don't know, depends on how much exhuast you can push to it, and the size of the turbo.</TD></TR></TABLE>
Think about it, .............exhaust heat being bypassed.
Old Feb 5, 2006 | 09:35 AM
blackeg's Avatar
you wont make as much/boost and have an exhaust leak out of the dumptube
Old Feb 5, 2006 | 09:40 AM
BlueSi2k's Avatar
the turbo cant overspin from that...it takes exhaust gas to spin it and by having the wastegate open your letting the exhaust out before it makes it to the turbo. If you disconnect a charge pipe then you can overspin the turbo.
ilikebigbutts
Dec 20, 2006 05:46 PM
2kTeg
Apr 20, 2005 02:45 PM
jdmfun99
Dec 6, 2004 05:33 PM
hondafanatic1
Feb 26, 2004 06:13 AM
nd8ch
Aug 26, 2003 04:47 AM
