Catch Can question
Old Jan 14, 2006 | 07:30 PM
Sketch_hs's Avatar
Default Catch Can question
Okay so i got the plugs for the back of the block. Whats the best catch can kit that i can just buy that will work with those two plugs? anyone else doing it this way?
okay thanks
Old Jan 14, 2006 | 07:49 PM
miro_gt's Avatar
Default Re: Catch Can question (Sketch_hs)
is this a B block ? .. because I'm having a D one and I was thinking whether or not those plugs would work for me
Old Jan 14, 2006 | 07:57 PM
Sketch_hs's Avatar
b18b block (lsvtec)
Old Jan 14, 2006 | 08:04 PM
fastforwardracer's Avatar
Default Re: (Sketch_hs)
endyn !! just hooked mine up 2day
Old Jan 14, 2006 | 08:05 PM
Dunc's Avatar
BCICAN
The Endyn catch can is great.... and I'm running an ls/vtec as well
Old Jan 14, 2006 | 08:18 PM
Sketch_hs's Avatar
using the ports on the back of the block?
where/how did you mount it?
Old Jan 14, 2006 | 08:31 PM
yes, kit for the b series comes with the peices you bought. in my 99 si mounted just beside the battery ran the breather lines to the block. a drain at the bottom of the catch can is a drain hose you t into 1 of lines you ran to the block. ibought it a while back for i think 150ish. came with everything you would need to hook it up, even if you live in the areas with the ozone police you can have the pcv valve hooked up. the distruction manuel will tell you everything you need to hook it up either way. the H series is a little diffrent, not sure about the D, F, OR K series setups.
Old Jan 15, 2006 | 08:07 AM
QuickEJ6's Avatar
Endyn already sell the anti syphon plugs with the breather kit you dont need those honda plugs... but Endyn use Moroso Catch Can.
Old Jan 15, 2006 | 08:22 AM
Sketch_hs's Avatar
anyone have mounted/installed pics?
Old Jan 15, 2006 | 08:24 AM
DRIVENRacing's Avatar
gonna run the z10 one.. come with the back of the block fittings, and a filtered can..
Old Feb 2, 2006 | 08:53 PM
blkcivichatch's Avatar
bump
Old Feb 4, 2006 | 11:32 PM
JDM00SI's Avatar
Default Re: Catch Can question (blkcivichatch)
endyn kit has eveyrthing, i regret not buying it.
Old Feb 5, 2006 | 06:08 AM
jayman322's Avatar
Default Re: Catch Can question (JDM00SI)
who is selling the endyn kit, i need one! pm or link me to honda-tech sponsors!
Old Feb 5, 2006 | 06:45 AM
raiden571's Avatar
i would have just run a slasch cut into the exhaust but,ehh
Old Feb 5, 2006 | 06:51 AM
jdm civic 2000's Avatar
Default Re: (raiden571)
here's where to buy one
http://www.theoldone.com/
Old Feb 5, 2006 | 10:16 AM
DRAGWORKS's Avatar
Default Re: (jdm civic 2000)
I just purchased one from stan at fast turbo.
scspeed
Apr 26, 2008 06:58 AM
JoseCuervo
Feb 14, 2006 02:02 AM
Trooper
Sep 29, 2003 05:17 PM
