Trouble Shifting Question
Old Jan 31, 2006 | 09:19 AM
Jesterian's Avatar
Default Trouble Shifting Question
I have trouble putting my car into gear sometimes and when I'm shifting it doesn't run through the gears smoothly like it used to. I had a tranny lube leak that I had fixed a while ago and it is full of honda transmission fluid. It still behaves like that. What else could it be?
Old Jan 31, 2006 | 08:09 PM
1RMDave's Avatar
Was it all of a sudden or kind of a gradual thing. Possibly shifter bushings?
Old Jan 31, 2006 | 08:21 PM
jdmcars.com's Avatar
Default Re: (1RMDave)
Also -is it only in the higher rev's or is it just about anytime?
Meaning, if you drive it, and try to shift at 3k, feel okay? How about 5K, and 7k?
Old Jan 31, 2006 | 08:28 PM
Jesterian's Avatar
Default Re: (jdmcars.com)
They all feel fairly sticky. I'm actually getting new shifter bushings right now, so if that's it I'll be solving the problem.
Old Jan 31, 2006 | 08:31 PM
jlicrx's Avatar
Default Re: (Jesterian)
have you tried adjusting the clutch?
Old Jan 31, 2006 | 08:33 PM
Jesterian's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">have you tried adjusting the clutch?</TD></TR></TABLE>
No.
Old Jan 31, 2006 | 09:11 PM
boostinaintez's Avatar
time for a rebuild or a new tranny. sounds like your syncros are going
Old Feb 1, 2006 | 11:00 AM
Jesterian's Avatar
Default Re: (boostinaintez)
It's a low milage tranny that I got with an hmotors swap. Can the synchros go if you run it low on lubrication for a little bit?
Old Feb 1, 2006 | 11:20 AM
Skidtron89's Avatar
Yes they can and make sure your clutch cable is adjusted correctly as well but if you ran it low on fluid it could be damaged but I doubt it unless you beat it a lot while it was low.
Old Feb 3, 2006 | 09:23 PM
Default Re: (Skidtron89)
did you adjust your cable properly?
hondateg10
Jul 22, 2008 03:54 AM
o0Jash0o
Jun 9, 2006 04:08 AM
baonest
Dec 19, 2005 02:16 PM
SpoolinEK9
Sep 20, 2004 10:33 AM
TurboBumblBee
11
Feb 22, 2004 10:22 PM
