Trouble Shifting Question
I have trouble putting my car into gear sometimes and when I'm shifting it doesn't run through the gears smoothly like it used to. I had a tranny lube leak that I had fixed a while ago and it is full of honda transmission fluid. It still behaves like that. What else could it be?
Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">have you tried adjusting the clutch?</TD></TR></TABLE>
No.
No.
Re: (Jesterian)
Yes they can and make sure your clutch cable is adjusted correctly as well but if you ran it low on fluid it could be damaged but I doubt it unless you beat it a lot while it was low.
TurboBumblBee
11
02-22-2004 10:22 PM
