Fitting a VENOM I-M. PLEASE HELP!!!
Old Jan 19, 2006 | 01:16 AM
kenb16a's Avatar
Default Fitting a VENOM I-M. PLEASE HELP!!!
Ive revently bought a Venom intake manifold for my eg9, b16a2 motor.
Fitting it seems to be a problem.., it only has 4 DRILLED holes at the back which are taped, i
ve taken it to few people, and they are not sure what exactly to do,
i can figure 4 holes are the back are for:
1) brake booster
2)to the purge solenoid
3)to the iavc
4) to the FPR
Now the problem, if you have a look at a standard b16a manifold then there are more then 4 things connected to it,
Could someone tell me how i should go about doing this, and if i should get, as someone siad a 'vacuum manifold'
but how does that work?
or would i be better just tapping some more holes in my self?
Guess someone who has alreayd fitted a Venom can really help me here..,
Old Jan 20, 2006 | 02:22 AM
kenb16a's Avatar
Default Re: Fitting a VENOM I-M. PLEASE HELP!!! (kenb16a)
Someone must have fitted one and can guide me please!!
Old Jan 20, 2006 | 03:08 AM
Redline96LX's Avatar
* B A N N E D *
its just a chunk of aluminum, just a manifold.
if you need more **** that requires vacuum, just get some more hose, get some T-connectors, and tap off of that. vacuum is vacuum, theres no problem with doing this.
Old Jan 20, 2006 | 05:10 AM
kenb16a's Avatar
i searched for VENOM on the site, few people of mentiiooned adapters of some sort, but nothing clear... can someone put light on this please??
Old Jan 20, 2006 | 05:29 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (kenb16a)
Vaccum is vaccum. T off one of the fittings if you need more lines. Problem solved!
Old Jan 21, 2006 | 03:29 AM
kenb16a's Avatar
ok thats sorted, but how about the iacv, if i run this to the back, my car wont idle right, how do i re-run this? do i need an adapter?
kenb16a
Jan 18, 2006 10:16 AM
miataguy
Jun 15, 2004 08:43 AM
miataguy
Jun 14, 2004 07:43 AM
Jx3069
Aug 27, 2003 07:21 AM
