my last resort!?
Someone Who has fitted or knows how to fit a VENOM i-m PLZ!!
Ive revently bought a Venom intake manifold for my eg9, b16a2 motor.
Fitting it seems to be a problem.., it only has 4 DRILLED holes at the back which are taped, i
ve taken it to few people, and they are not sure what exactly to do,
i can figure 4 holes are the back are for:
1) brake booster
2)to the purge solenoid
3)to the iavc
4) to the FPR
Now the problem, if you have a look at a standard b16a manifold then there are more then 4 things connected to it,
Could someone tell me how i should go about doing this, and if i should get, as someone siad a 'vacuum manifold'
but how does that work?
or would i be better just tapping some more holes in my self?
Guess someone who has alreayd fitted a Venom can really help me here..,
Modified by kenb16a at 11:03 AM 1/18/2006
1) brake booster
3)to the iavc
4) to the FPR
the Stock intake mani has coolant lines running to it . . .my guess is that the venom i-m did away with the coolant lines . . in witch case you'll have to re route them. . . . just my 2 cents
Re: my last resort!? (kenb16a)
you should have bought a type r , blox, or skunk 2. They are so much easier to install. If the man. doesn't have coolant routes, then i would just route the lines within the engine. Just bypass the manifold thtas all.
grammer nawzi
Re: (kenb16a)
Maybe you should have made your title a little more descriptive, you know, something with the problem in it. I doubt that people are really going to click on it. Anyways, just reroute the coolant.
kenb16a
01-21-2006 03:29 AM
