vacuum routing help
vacuum routing help
I replaced my my intake manifold with aebs, and need help with vacuum routing. I'm not sure were most of the stuff is supposed to plug in. It was messed up before the intake manifold was installed, I'm just trying to fix everything.
First problem is the vacuum line from the top of the FPR isn't going anywhere. On the diagram, it looks like its supposed to plug into someplace on the firewall, but I can't find it.
Second problem is the two-way valve routing on the charcoil canister. One hose is supposed to go the throttle body, but for some reason mine doesn't have an inlet. A post here has it, but for some reason I don't. The other hose is supposed to go to the firewall somewhere; again I can't find where.
Next, there is a hose coming up from under the intake manifold(comes up through a hole between second and third runner). On my old manifold, it just plugged into an inlet on the front of the manifold. New manifold doesn't have an inlet on the front of the manifold, So I just got a longer house and plugged it into the back. I'm not sure if thats where its supposed to go. I've have put pics below.
gnccracer18
03-24-2008 06:14 PM
kenb16a
01-21-2006 03:29 AM
Nextelbuddy
03-26-2004 05:08 PM
