*** HELP: Turn Signals Not Working ***
Old Jan 9, 2006 | 12:00 PM
integlspwr2k's Avatar
Default *** HELP: Turn Signals Not Working ***
I have a 1996 civic HX coupe. The turn signals stopped working. Before it stopped working, it would blink like twice and then it would stay on solid. Then after a while, it just completely stopped working.
I replaced my turn signal relay and that didnt solve the problem. My hazard lights do work, but when i signal left and right, they do not.
Any suggestions on stuff i can check?
Thanks In Advance.
-integlspwr-
Old Jan 9, 2006 | 12:03 PM
Tippyman's Avatar
Did you check fuses? Grounds? any shorts?
Old Jan 9, 2006 | 12:11 PM
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">Did you check fuses? Grounds? any shorts?</TD></TR></TABLE>
fuses = not yet. (do you know which fuse should i be checking to see if its burnt?
grounds / shorts = not even sure where to start to check those..
Old Jan 9, 2006 | 12:14 PM
Baggy Spandex's Avatar
Default Re: (integlspwr2k)
does everything else work, such as your instrument panel lights?
Old Jan 9, 2006 | 12:21 PM
Default Re: (NAisBEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST &raquo;</TD></TR><TR><TD CLASS="quote">does everything else work, such as your instrument panel lights?</TD></TR></TABLE>
the cluster lighting works, so does the lighting behind the climate control area...
Old Jan 9, 2006 | 03:37 PM
Default Re: *** HELP: Turn Signals Not Working *** (integlspwr2k)
im sad.. no turn signals suck.
Old Jan 10, 2006 | 11:25 AM
Old Jan 10, 2006 | 11:30 AM
sohcvtec1995's Avatar
relay/flasher is bad. when the lights were staying on that was the relay/flasher sticking. then when it stopped working that was the relay/flasher poping. so just change the relay/flasher and your good..
Old Jan 10, 2006 | 11:32 AM
dohcVTECeg2's Avatar
Default Re: *** HELP: Turn Signals Not Working *** (sohcvtec1995)
check your underhood fuses. you probably blew your hazard fuse
Old Jan 10, 2006 | 11:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">relay/flasher is bad. when the lights were staying on that was the relay/flasher sticking. then when it stopped working that was the relay/flasher poping. so just change the relay/flasher and your good..</TD></TR></TABLE>
i did change my relay / flasher to a new oem one from the dealer, and still no turn signals.
Default Re: *** HELP: Turn Signals Not Working *** (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">check your underhood fuses. you probably blew your hazard fuse</TD></TR></TABLE>
but my hazards work when i press the hazard button...
Old Jan 10, 2006 | 07:51 PM
Sumslapper's Avatar
Year 3030
do your tail lights light up? i can garantee its probably just a fuse. Especially if both of them are out at the same time.
Old Jan 10, 2006 | 09:18 PM
Default Re: *** HELP: Turn Signals Not Working *** (sumslapper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">do your tail lights light up? i can garantee its probably just a fuse. Especially if both of them are out at the same time. </TD></TR></TABLE>
ya tail lights work, brake lights also work.
I'll check the turn signal fuses tommrow and post back.
Old Jan 12, 2006 | 11:31 AM
xaznxdrgnxboix
Jan 29, 2008 06:21 AM
ricsosan_no5
Nov 2, 2007 09:05 AM
MR Rodgers
Aug 25, 2007 01:56 PM
prelude_2k1
Jul 14, 2004 08:32 AM
FBP Si 2000
Dec 23, 2003 05:16 PM
