turning signal help
Old 01-27-2008, 10:04 AM
xaznxdrgnxboix's Avatar
Default turning signal help
i have a 94 civic hatch and my turning signals just stop working out of no where. Could anyone help me? thnx
Old 01-27-2008, 10:13 AM
Civicman86's Avatar
Did you check your fuses?
Is it just your turn signals that stopped or is there any other lights that have stopped as well?
Old 01-27-2008, 10:16 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: (Civicman86)
If your hazard light button is fualty turn signals won't work either.
Old 01-28-2008, 06:50 PM
Default Re: (mcvtec)
I didn't check the hazard light cause i figure that is out to. But yeh only the signals dont work everything else works fine.
Old 01-28-2008, 06:58 PM
hgem1si's Avatar
Default Re: (xaznxdrgnxboix)
Uhm.. I've had to replace a flasher before in an older car...? Idk maybe.
Old 01-28-2008, 07:03 PM
Default Re: (hgem1si)
lol it might be. How do you do that haha?
Old 01-28-2008, 10:16 PM
hgem1si's Avatar
Check this site out while I figure out how to do it on your car.
http://www.britts.procarcare.c....html
Old 01-29-2008, 06:21 AM
Resident Gearhead
BryanM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">If your hazard light button is faulty turn signals won't work either.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxdrgnxboix &raquo;</TD></TR><TR><TD CLASS="quote">I didn't check the hazard light cause i figure that is out to. But yeh only the signals dont work everything else works fine.</TD></TR></TABLE>
Ok, put it this way. If you disconnect the hazard light ("flashers") button your turn signal lights won't work. So if it's faulty - worn out, broken etc - ya get no turn signals.
Checking/replacing the hazard light on a 92-95 Civic is easy. Simply pry it out of the dash trying hard no to scar up the plastic. It's got a connector on the back comes off easy.
revvhavok
08-30-2009 08:19 AM
ricsosan_no5
11-02-2007 09:05 AM
2.2L EH2
10-10-2006 11:10 PM
integlspwr2k
13
01-12-2006 11:31 AM
tur3oDC4
07-02-2005 01:21 AM
Quick Reply: turning signal help
