GM 3 bar MAP sensor with missing link
I know that the missing link goes between the MAP sensor and the TB, but will a GM 3 bar bolt pattern line up with the TB and missing link or is there another way of installing it.
if u do get a 3bar u will need to run a program like uberdata,crome, hondat that has 3-bar support. dont put a 3bar on ur stock ecu and expect to hit 16 psi of boost.... or even get the car to drive!
