3 bar map sensor
Old Jun 4, 2002 | 08:32 PM
dc r-spec's Avatar
Default 3 bar map sensor
hey do you need to have a hondata or another stand alone system to run the 3 bar map or does it justplug into the stock ****. Running a missing link and want to run more than 11 pounds and won'tmy ecu see that after11 pounds. Thanks
Old Jun 4, 2002 | 08:54 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: 3 bar map sensor (dc r-spec)
No you cant plug it into your stock ****, and you can use the missing link past 11psi..
art
Old Jun 4, 2002 | 09:23 PM
rice4life's Avatar
Default Re: 3 bar map sensor (Arturbo)
if you are using a missing link, your ecu does not see any boost at all. so it doesn't matter how much boost you run.
Old Jun 4, 2002 | 10:30 PM
bigTom's Avatar
Default Re: 3 bar map sensor (rice4life)
untrue... the missing link isnt a 100% on point at all times... sometimes they will throw codes
Old Jun 4, 2002 | 11:36 PM
98civicEX's Avatar
what if you're using the V-AFC hack, i can't boost past 12psi w/o throwing a code. So can i purchase the 3 bar map sensor and kiss that problem goodbye? or can i just put the missing link in?
standbackimapro
Jun 8, 2008 11:54 AM
QwkD16
Jan 5, 2006 07:39 PM
B18Sleeper
Oct 26, 2005 12:52 PM
l2yanE
Oct 2, 2005 10:15 AM
gsrt2c
Jun 8, 2003 05:35 AM
