GM 3 bar MAP sensor with missing link
Old Jan 5, 2006 | 03:11 PM
QwkD16's Avatar
Default GM 3 bar MAP sensor with missing link
I know that the missing link goes between the MAP sensor and the TB, but will a GM 3 bar bolt pattern line up with the TB and missing link or is there another way of installing it.
Old Jan 5, 2006 | 03:36 PM
Jared's Avatar
The purpose of having a GM map sensor is so you can read 10+ psi. Why do you want to use a missing link with it? And the GM 3 bar is not even close in size to a stock Honda.
Old Jan 5, 2006 | 03:38 PM
QwkD16's Avatar
Default Re: (Jared)
Well that was basiclly my question, If I even needed the missing link. If not then I dont want to use it.
Old Jan 5, 2006 | 03:45 PM
StolenTeg's Avatar
Default Re: (96SCd16)
you dont want to use it because it doesnt uses the missing link>?
Old Jan 5, 2006 | 03:48 PM
QwkD16's Avatar
Default Re: (StolenTeg)
I dont want to use the link or the 3 bar? I want to run about 16 psi.
Old Jan 5, 2006 | 06:31 PM
StolenTeg's Avatar
Then get a 3 bar sensor and your all set, no missing link needed
Old Jan 5, 2006 | 07:39 PM
boosted k20's Avatar
if u do get a 3bar u will need to run a program like uberdata,crome, hondat that has 3-bar support. dont put a 3bar on ur stock ecu and expect to hit 16 psi of boost.... or even get the car to drive!
standbackimapro
Jun 8, 2008 11:54 AM
B18Sleeper
Oct 26, 2005 12:52 PM
redlseg
May 11, 2005 06:48 AM
gsrt2c
Jun 8, 2003 05:35 AM
dc r-spec
Jun 4, 2002 11:36 PM
