3bar map vs missing link
Old Jun 7, 2003 | 05:45 PM
gsrt2c's Avatar
Default 3bar map vs missing link
if you already have a missing link couldnt you use that instead of a 3 bar map sensor when you run over 10 pounds on an afc if not why not?
Old Jun 8, 2003 | 05:11 AM
Big Daddy Go Fast's Avatar
According to the manufacturer info. the "missing link" is good to 60 lbs of boost.
Old Jun 8, 2003 | 05:35 AM
ladysman's Avatar
Default Re: 3bar map vs missing link (gsrt2c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrt2c &raquo;</TD></TR><TR><TD CLASS="quote">if you already have a missing link couldnt you use that instead of a 3 bar map sensor when you run over 10 pounds on an afc if not why not?</TD></TR></TABLE>
You can't use the 3 bar map sensor with stock Honda ecu even with the AFC hack. It has different voltages than the stock MAP sensor so the engine will run like ****.
QwkD16
Jan 5, 2006 07:39 PM
B18Sleeper
Oct 26, 2005 12:52 PM
l2yanE
Oct 2, 2005 10:15 AM
redlseg
May 11, 2005 06:48 AM
dominate9
Nov 15, 2003 01:01 PM
