lugs and studs
My friend has a civic. Somehow he managed to break three out of four wheel studs. When we take the rotor and caliper off but were having trouble getting the old studs out.
My question is: Does any one have online directions showing how to change wheel studs on a Honda, specifically a 2000 civic.
(Please under stand I'm a novice)
There is some kind of metal piece behind the rotor that is preventing the studs form coming out. my friend has referred to it as a "hub".
my friend says "you cannot remove the studs becuase there is steel behind them
WILLYDAWSON V: you have to remove the hub assembly to be able remove the studs "
I'll admit the tech forum does sounds a little better of an idea. Although, there is a lot of knowledge on this forum and this is were I visit on a daily basses, so I thought I would post here. BTW, thanks for the help, all they need was a good hit
. Thanks again.
Luke
. Thanks again.Luke
CHONCH
22
Dec 1, 2003 09:21 PM
