extended studs help
Old Jan 2, 2010 | 12:11 PM
heyimrchills's Avatar
Post extended studs help
i've been looking for articles but i haven't found any or i put in the wrong search words..
i'm wondering if any of you guys have articles or info to convert my regular 4 stud to extended studs? and how much is the price range to do it?
if its too expensive i mind as well go 5 lug conv. than go extended
Old Jan 2, 2010 | 01:55 PM
Double Agent's Avatar
Default Re: extended studs help
Somebody correct me if I'm wrong, but extended studs are so you can fit wider wheels with more offset for slicks, and aren't necessarily stronger. Although I'm sure companies like ARP make stronger than stock studs.
Old Jan 2, 2010 | 04:56 PM
tsdneil's Avatar
are you asking how to do it, or if 5 lug conversion is cheaper than extended studs?
to convert to extended wheel studs all you do is
1. jack up car
2. remove wheels
3. remove wheel bearing retaining nut
3. remove brake caliper
4. remove brake rotor
5. use hub puller tool and slide hammer to remove hub
6. press out old studs
7. install new extended studs
8. put it all back together.
usually when you disassemble the hub you are supposed to replace the wheel bearing. if you use the slide hammer method rather than taking it to a shop to do this, you risk breaking your wheel bearing and having to replace it, but if you take it to a shop, they might break your wheel bearing too. if you do it yourself, it is much cheaper than a 5lug conversion. its not too hard, should take a couple hours. just did mine last week.
Old Jan 2, 2010 | 09:43 PM
yesirthepoptart's Avatar
Post Re: extended studs help
1. jack up car
2. remove wheels
i was wondering how much it would cost etc. and how to do it because i want to do it before i save up to get konig retrack's with the new 3" lip.
i want to "DIY" it but iits my first time any articles on this?
nice car and wheels btw! DA?
Old Jan 2, 2010 | 11:05 PM
i was going to ask the same thing as ^^.
bump
Old Jan 2, 2010 | 11:07 PM
i was also wondering besides how to articles or info to make my car have extended studs how do you make your wheels wider/*more out the fender* using spacers??
Old Jan 2, 2010 | 11:12 PM
pi Ka chuuu's Avatar
i dont see why u would consider 5 lug conv or extended studs? they arent really relevant to each other lol if ur gonna drag race get extendeds, if ur tryna style go 5 lug i guess
Old Jan 2, 2010 | 11:19 PM
yeah idk why i was considering later on a project with a friend to do 5 lug but iono i thought it would be the same price range LOL? extended are they hard to install? *like i said before-articles/info DIY?
Old Jan 3, 2010 | 12:29 AM
tsdneil's Avatar
yeah, its a DA. you can use spacers to move the wheel away from the car more, but the proper way to get good fitment on a wheel is to do some research on offsets and wheel widths. it only took me about 3 hours total to do all 4 wheels. it was a prety basic thing. ive never removed a hub before and i was skeptical at first, but i got it all apart pretty easily. the extended studs cost about $85. i rented a hub puller from autozone for about $50 and it came with the slide hammer. so really the extended studs will run you about $85 and a couple hours of time. you get your money back when you return the hub puller, so that was free. much cheaper than 5 lug conversion. i cant find any of the articles i used, but do some searches on google and youtube and it should be more than enough info to do the job. nothin' to it, but to do it!
Old Jan 3, 2010 | 05:43 PM
noo its def not the same price range. going 5 lug is alot more expensive and requires more work. installing extended studs is not a difficult job but it takes a couple of hours if u take ur time and do everything at a good pace. check on here theres plenty of write ups on how to
marvin75
Apr 24, 2011 05:48 AM
piotrush
Honda Civic (2006 - 2015)
18
Jul 4, 2009 08:31 PM
CHONCH
22
Dec 1, 2003 09:21 PM
EK MONEY
Nov 2, 2002 05:47 PM
reese
Jul 14, 2002 10:32 PM
