Alignment
Old Mar 14, 2002 | 02:16 PM
Solo2Vtec's Avatar
Default Alignment
Just got a new set of Falken Azenis and I was wondering where the best place to get an alignment is. Thanks Guys!
Old Mar 14, 2002 | 02:19 PM
RyanR's Avatar
Default Re: Alignment (LSVtec2000)
Since your in Redondo beach, give Johnsons Alignment a try. They're over in Torrance. I've been there a couple of times and they provide excellent service.
Old Mar 14, 2002 | 02:20 PM
yoshi234's Avatar
I shoot brides
Go to West End Alignment in Gardena and talk to Darin. He also does corner weighting for adj coilovers.
18008 South Vermont Ave
Gardena, CA
310-808-9233
Old Mar 14, 2002 | 02:24 PM
ARunto's Avatar
Default Re: Alignment (yoshi234)
what toe settings do you set your cars with?
Old Mar 14, 2002 | 02:28 PM
yoshi234's Avatar
I shoot brides
Default Re: Alignment (ARunto)
max toe out in front, but still w/in spec
zero toe in rear
yshi - who gives this
Old Mar 14, 2002 | 03:04 PM
Solo2Vtec's Avatar
Thanks for the great info
Old Mar 14, 2002 | 03:43 PM
M12's Avatar
M12
If you go there, try it on a weekday. Much less people than on the weekend.
Old Mar 18, 2002 | 06:33 AM
nargenar's Avatar
New User
Default Re: Alignment (M12)
Please don't laugh at my lack of knoledge... does the Type R have 2 wheel or 4 wheel alignment? I just got new tires, and I need an to get an alignment done. My car is not lowered, or have any other suspension mods at all. So I go to the tire place I go to and say I want the MAX tow OUT (but within spec) for the front and 0 Tow in the rear???
Thanks a lot,
-Neeraj.
Old Mar 18, 2002 | 06:41 AM
yoshi234's Avatar
I shoot brides
Default Re: Alignment (nargenar)
no laughing here, that's what this board is for
does the Type R have 2 wheel or 4 wheel alignment? So I go to the tire place I go to and say I want the MAX tow OUT (but within spec) for the front and 0 Tow in the rear???
has 4 wheel alignment.
if this is just a street driven car, then go w/ the factory recommended toe settings.
if you autox or do open track type events, then max toe out in front and zero toe in the rear works great
yshi - who uses the latter setting
Old Mar 18, 2002 | 06:47 AM
ZygSpeed's Avatar
Yoshi, would you care to comment on what you consider "max in-spec front toe out"?
I've had mine set at 1/16" front toe out (evenly split), and zero rear. Ed
Old Mar 18, 2002 | 06:57 AM
Doctor CorteZ's Avatar
Default Re: Alignment (zygspeed)
ED - that should be the max toe-out within spec , 1/16th on each side
Old Mar 18, 2002 | 07:01 AM
ZygSpeed's Avatar
Default Re: Alignment (Doctor CorteZ)
I was under the impression Ben told me 1/16 total! (evenly split)
Unless I'm mistaken stock R spec is something like 0 degrees front toe.
Was this before or after you met Oscar?
George, since last June (hence, before).
[Modified by zygspeed, 11:03 AM 3/18/2002]
Old Mar 18, 2002 | 10:18 AM
nargenar's Avatar
New User
does having the MAX toe to spec wear the tires faster? I do auto cross and try to get to 2-3 track days per year.... so I would like the extra advantage, but not if it wears the tires a lot more...
thaks
neeraj
The-Kid
Southern California
Jul 11, 2011 11:14 AM
mr abstract
Suspension & Brakes
Dec 10, 2006 02:42 PM
bb2prelude
Suspension & Brakes
Oct 13, 2005 08:19 AM
Armaan
Sep 7, 2003 09:45 AM
