Code 21 (VTEC Solenoid) clicking on, instead of VTEC engaging
Like the title says, there's no VTEC. It just throws a code 21.
Wiring was re-checked, and re-run, oil level is perfect, VTEC pressure switch is hooked up properly...
JDM B16A into '93 Civic with jdm P30 computer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu »</TD></TR><TR><TD CLASS="quote">is the motor warm? becuase it has to be at a certain temp before it engages... </TD></TR></TABLE>
yep, everything is warm, no other codes either.
Sounds to me like an ECU.
mine does the same ****..has code 21..b4 i just had tps code n it went away out of no where n i have a vtec code now instead..goes tttzz at 6K..no vtec sucks..let me knoe if you fix ur problem
keychild486
11
Apr 2, 2008 06:28 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
1.8EG-T
Mar 10, 2002 05:56 PM
