Ideas For Ls/vtec
Old Dec 11, 2005 | 04:49 PM
Green98Integra's Avatar
Default Ideas For Ls/vtec
Should i do a gsr or type r head?
Old Dec 11, 2005 | 04:55 PM
mmuller's Avatar
Mad Scientist
Default Re: Ideas For Ls/vtec (Green98Integra)
well the p73 head (type r) is a better overall package; afait more expensive.
But if you had to pick between the pr3 and p72 head go with the p72(gsr)
Old Dec 11, 2005 | 05:03 PM
Default Re: Ideas For Ls/vtec (mmuller)
WHich would be better for later turbo
Old Dec 11, 2005 | 05:58 PM
Korch94's Avatar
get the gsr head and put the extra money you save towards some good headwork imo
Old Dec 11, 2005 | 08:51 PM
psegs80's Avatar
Default Re: Ideas For Ls/vtec (Korch94)
If $$$ is an issue, go with b16a head, p30 pistons in your bottom end ( don't forget arp rod bolts)and get CTR cams....you will be able to keep stock b16a valvtrain!
( if you don't mind sending the engine off to a good machine shop, get +0.25 ctr pistons and a port n polish...your ctr cams will like that)
Old Dec 12, 2005 | 03:04 PM
Default Re: Ideas For Ls/vtec (psegs80)
Money aint an issue. But should i go all motor or should i turbo?
Old Dec 12, 2005 | 04:15 PM
Korch94's Avatar
thats kinda somthing u should decide for yourself
i chose all motor but that was me
just search for some pros and cons of each and see what fits u better
Old Dec 12, 2005 | 06:27 PM
rkrone's Avatar
turbo!!!!! way more fun, and if you have the $$$, then its even better
but it takes longer, and you have to do your research....
Old Dec 14, 2005 | 07:02 PM
Default Re: Ideas For Ls/vtec (rkrone)
Ideas for what brand of turbo?
Old Dec 14, 2005 | 07:27 PM
EB90RS's Avatar
IMO the gsr head is better for lsvtec i hear because the compressions on the itr is to much and more likely to blow your motor. Either way sooner or later your motors going to blow and lsvtec is not such a good idea unless you have another motor waiting to be put in. with out a doubt tho if you have money lsvtec is pretty crazy and something fun to do
dtbrk15
Apr 2, 2012 06:41 AM
crxowner
18
Mar 8, 2007 01:20 PM
B-JUSTINE
Apr 6, 2006 06:17 AM
crxste
Aug 19, 2003 08:16 PM
Sideshow9090
Jun 18, 2002 07:58 PM
