Timing too advanced?
Old Oct 19, 2005 | 10:23 PM
elpiar's Avatar
Default Timing too advanced?
I have a t3 60trim on B18C1 with uberdata.
Timing is 17.25 (low cam) and 23.25 (hi cam) from 5k upward @ 10 psi. Anyone running similar timing? Is this conservative enough?
I don't wanna blow my engine (yet!)
Old Oct 19, 2005 | 11:25 PM
adseguy's Avatar
Default Re: Timing too advanced? (elpiar)
that's quite a bit. Low cam is conservative and hi cam is a bit aggressive without a dyno. I'd stay around 19-20 without a dyno. 21 if you know how to check everything. Check your plugs frequently at first for any signs of detonation and to see if the ground strap is correct
Old Oct 20, 2005 | 06:54 AM
elpiar's Avatar
Default Re: Timing too advanced? (adseguy)
thanks for the reply!
I guess maybe I am running too aggressive. Anyone else?
This is my plugs:
https://honda-tech.com/zerothread?id=1407600
Old Oct 20, 2005 | 11:33 AM
boosted k20's Avatar
on boosted cars at 10 psi i set timing to 19*
Old Oct 20, 2005 | 05:10 PM
elpiar's Avatar
Default Re: Timing too advanced? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">on boosted cars at 10 psi i set timing to 19*</TD></TR></TABLE>
Now I'm a lil worried
I'm gonna have dyno day on sunday, got 3 pulls, what are some of the timing you suggest me to run.
Btw, when you say 19* it's for hi cam right?
Old Oct 20, 2005 | 07:06 PM
yup 19* high cam timing. try 19* first then when ur on the dyno add 1 * timing, if the TQ increases then try to add another 1/2 - 1 degree. once the tq does not increase, back off the timing by like 2* to keep the motor safe
Old Oct 20, 2005 | 07:14 PM
N20civicB18's Avatar
ehhh im set at 26º at full boost
Old Oct 20, 2005 | 07:31 PM
Default Re: Timing too advanced? (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">ehhh im set at 26º at full boost</TD></TR></TABLE>
if the motor is built w/ low compression pistons and/or bigger displacement than 1.8liter, then i say 26* aint that bad. but for a stock motor, 26* at 10psi seems a bit too much timing
Old Oct 20, 2005 | 07:34 PM
elpiar's Avatar
what psi?
Did someone tune it for you?
Old Oct 21, 2005 | 03:29 AM
ccivic's Avatar
Do a pull.. shut off around 5500 rpms and pull the plugs.. see if there's any specks of anything on them. If there is.. back off the timing and do it again.
Old Oct 21, 2005 | 03:48 AM
AMS-Tuning set everything for me, we only did street tuning. I should prob go look at the plugs
Old Oct 21, 2005 | 06:49 AM
Importordomestic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">AMS-Tuning set everything for me, we only did street tuning. I should prob go look at the plugs</TD></TR></TABLE>
well it cant be that bad, pending on how many miles you have ran, your motor hasnt blown YET!
Old Oct 21, 2005 | 06:56 AM
elpiar's Avatar
Default Re: Timing too advanced? (Importordomestic)
Ok. So for Hi cam, I will start from 19* on the dyno.
I wonder whether the low cam matters at all beyond vtec transition, but how much timing do you guys run @10 psi?
Old Oct 21, 2005 | 08:56 PM
VTC_CiViC's Avatar
So you just arbitrarily set all turbo'd Honda's to 19* BTDC @ 10psi eh?
LSEGHATCH
Apr 23, 2007 03:16 PM
bb6h22
Oct 11, 2004 10:28 PM
Civic_95_Si
Oct 24, 2002 01:09 PM
eargrub
May 16, 2002 11:00 AM
