if your engine lack of power and acceleration read this.
Old Oct 19, 2005 | 03:05 PM
CivicHP's Avatar
Default if your engine lack of power and acceleration read this.
i recently swaped an jdm d15b vtec and notice a bit of difference then my old d15b7 but i felt it was lacking in acceleration and in hills the car was stugling i knew something was not right and was not running like it should. so i checked my catalytic converters and i was completly shocked it was completly clogged i replace it with a magnaflow direct bolt on and oh boy it felt like a new car. a lot more acceleration no more struggling in hills. so all of you who have those symptons you might want to check that bastard it probably need to be replaced.
Old Oct 19, 2005 | 03:09 PM
Project_DX's Avatar
Default Re: if your engine lack of power and acceleration read this. (CivicHP)
going to do this soon
Old Oct 19, 2005 | 03:11 PM
ekcivic9's Avatar
would it be advisable to do this even though i dont have a swap :
Old Oct 19, 2005 | 03:16 PM
jameskersten1's Avatar
Default Re: (ekcivic9)
true. back about a year ago i had my cat in, and raced a buddies 94 Civic coupe dx, i won but barely, maybe half a car. I took my cat out just because i had a test pipe sitting there. WOW what a change. I raced my buddy again the next week and I smoked him by like 5 or 6 cars. I wasnt even close.
Old Oct 19, 2005 | 03:18 PM
CivicHP's Avatar
also true but if you choose to run a cat make sure it in good condition.
Old Oct 19, 2005 | 03:21 PM
CivicHP's Avatar
doesen't matter if you did not do a swap. if it clogged you will see a big difference.
Old Oct 19, 2005 | 03:40 PM
Default Re: (CivicHP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHP &raquo;</TD></TR><TR><TD CLASS="quote">also true but if you choose to run a cat make sure it in good condition.</TD></TR></TABLE>
only reason I ran the stock cat in the first place was i was in a rush to finish the swap and I didnt have time to get an o2 sensor bunged in so my only other option other then no o2 was to run the stock cat. It was ok for a little while but after about a yr i noticed the motor was lacking.
Old Oct 19, 2005 | 05:10 PM
Squallie's Avatar
Default Re: (jameskersten1)
where can i pick one up for a stock USDM D15b7? and how much did it cost u?
Old Oct 19, 2005 | 05:21 PM
handa's Avatar
Default Re: (Squallie)
Would a bad resonator cause this issue too?
Check out all the threads I've made over the years concerning this similar issue:
https://honda-tech.com/zerothread?id=1235955
https://honda-tech.com/zerothread?id=1203316
https://honda-tech.com/zerothread?id=1099978
https://honda-tech.com/zerothread?id=1079747
https://honda-tech.com/zerothread?id=1030791
The never ending story. I still have the problem. Gutted the cat won't help...getting a high flow cat soon. I believe it's my stupid resonator on my exhaust piping.
Old Oct 19, 2005 | 05:32 PM
Arsenal's Avatar
How many miles were on your CAt?
Old Oct 19, 2005 | 09:09 PM
ekcivic9's Avatar
how can u tell if the cat is clogged?
Old Oct 19, 2005 | 09:23 PM
wob's Avatar
wob
by how much exhaust is escaping the tailpipe i suppose...it can get real sophisticated too.. theres tools that measure exhaust back pressure.... i remember one time i thought my hesitation was caused by a clogged cat.. it turned out to be hollow tho.. it ended up being a weak coil..
Old Oct 19, 2005 | 09:29 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">how can u tell if the cat is clogged?</TD></TR></TABLE>
Take off the cat, look through it. If you cant see the other side its clogged.
Old Oct 20, 2005 | 06:11 AM
CivicHP's Avatar
my cat had about 175 000 miles. i bought the cat for 140 $CAD so it should not be more then 100$US you can buy it at any auto parts store or online http://www.magnaflow.com/03buyonline.asp
to see if your cat is clogged you have to check it from the entry that goes to the downpipe cause it there it get clogged.
handa it could be your resonator try to remove it. i would sugest you this remove all you exhaust system to the downpipe and drive it that will tell you if it your exhaust system. if it not might be a sensor.
Old Oct 20, 2005 | 06:17 AM
92ehatch's Avatar
my at has 206k on it, may be my lag problem.
however mine only lags it seems from 2-4 k at 5 k and up it feels like vtec, even tho i have no vtec
i shall check my cat as well see if it help
Old Oct 20, 2005 | 06:43 AM
JDM-EJ1's Avatar
Default Re: if your engine lack of power and acceleration read this. (Project_DX)
I need to check mine, .
Old Oct 20, 2005 | 06:53 AM
alispoon's Avatar
my car has about 300 km on it now. does anybody think its about time for me to change mine cause i can feel my car hesetating.
Sleepythecivic
Dec 18, 2012 05:28 PM
sfjdmlud3
Jun 25, 2004 03:57 AM
H22A EG6
Jun 13, 2003 10:46 AM
hatchii
Nov 25, 2002 11:46 PM
