GSR OBD2 Problem=== Plz Help
Old Oct 18, 2005 | 06:16 PM
thewonderer's Avatar
Default GSR OBD2 Problem=== Plz Help
My car is bouncing between rpms when i give it gas. I have changed the IACV EACV and ECU and went through about 10 harnesses. Im still throwing the P1508 after changing these units and I have now received a TPS code. I changed my throttle body for a new edlebrock 64mm with a new tps on it. That cleared it up but i still got this problem. I cant rev over like i think 4K and i cant drive it cause its too limp. I cant even reach vtec or nothing. Please help wit suggestions and flaming isnt necessary. GSR info is low at the moment so this is my last resort.. thanks
Old Oct 24, 2005 | 08:26 PM
integraduo's Avatar
Default Re: GSR OBD2 Problem=== Plz Help (thewonderer)
are you sure it's not your dizzy? crank sensor?
I don't have an obd2 car, but that sounds like what my DA did when the dizzy went out.
good luck
VIc
Old Oct 24, 2005 | 09:02 PM
eknorcal's Avatar
did u do a compression test?
Old Oct 24, 2005 | 09:06 PM
Downey's Avatar
make sure ur tps is adjusted correctly. .5volts closed, 4.5volts at full throttle.
Old Oct 25, 2005 | 10:32 AM
The problem was a bad harness. I changed harnesses with a new one from honda and car functions perfectly. I swapped motors afterwards and the little hatchy pulling a 14.2 with a stock b16a2. thnks
greencivic_0789
May 24, 2011 01:22 AM
crnimacak
Jan 19, 2006 04:59 PM
speedy108
Dec 18, 2005 05:50 AM
imlachg1
May 6, 2004 09:57 AM
