Code 22 (searched)
Code 22 (searched)
My eg with a d16z6 is throwing a code 22. I have searched and found what it might be but I haven't found anything on how to fix it. I just want to know what sensor is causing this and can I try to clean it. I know it is a v-tec issue but I don't know if it the solenoid or if its a switch. If someone could help me out it would be greatly apreciated. Thanks
Re: Code 22 (wernhersey)
I just tried cleaning it and that didn't work either. And I also forgot to mention that everything seemed fine after the swap, the v-tec was and is still working and there were no CEL's.
code 22 is the oil pressure switch for vtec. replace oil switch and should solve your prob. i had a similar problem and switched fixed the issue. gl to ya
not the oil pressure switch in the back of the block, its the vtec pressure switch, it should be near the vtec solonoid, also remove the vtec solonoid housing and make sure the screen isn't stopped up, i think that if your oil level was low it will also set the code
cioli
12
02-26-2006 08:31 AM
drudy
08-07-2005 05:59 AM
