new winter project....400 lb/ft on 93 octane.
I am going to try a couple of different methods and try to push my h22 to 400 lb/ft. (i am a fan of massive torque) I am currently making 380 whp and 320 lb /ft w/ this set-up.
sleeved h22
9:1 compression
87mm bore
stock head, stock IM
720 injectors
t3/t4 60 trim turbo .63ar
18psi of boost 19 degrees total timing
adj cam gear w/ stock cams -3intake 0 exhaust
secondaries disabled
log manifold 2.25in DP
3intest pipe, 3in exhaust,
neptuneD
are there any suggestion as to what i should try to help bring up my tourqe /hp level.
I was thinking that a EL manifold and 3in DP would really help.
and maybe a different turbo.
but what key elements would i be looking to change on the turbo. A/r trim?
any h22 making similar # please post set-up.
thanks for the help boost heads,
later
sleeved h22
9:1 compression
87mm bore
720 injectors
neptuneD
later
Maybe a more traditional turbo cam, or bigger turbo. The cam with less overlap would probably give you more power where your peak tq is, I'm guessing around 5k. IMO the only way to more tq on a honda is to move farther up the powerband (and give it less of a traditional 'torquey' feel of v8's) or more displacement. Other than that, try a diff intake/exaust manifold and definately try to shoehorn a 3" dp in there.
I would also recommend Cooling Mist's meth injection kit if you are going to try for that much torque on pump gas.
http://www.coolingmist.com/
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">I would also recommend Cooling Mist's meth injection kit if you are going to try for that much torque on pump gas.
Good luck
cool..i'll look into that.
i am going to try a EL mainifold and a 3in DP w/ same turbo/same boost first and we'll see what happens..
Good luck
</TD></TR></TABLE>cool..i'll look into that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS »</TD></TR><TR><TD CLASS="quote">I'd recomend cams to move the powerband up and bigger turbo with like .82ar and yeah water/meth injection.</TD></TR></TABLE>
why would he want to move the powerband up? and get a larger a/r turbo which would cause more lag?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic »</TD></TR><TR><TD CLASS="quote">
i am going to try a EL mainifold and a 3in DP w/ same turbo/same boost first and we'll see what happens..</TD></TR></TABLE>
That will do it...The car we prototyped our h22 manifold on made 312whp @ 7psi with a 60 trim t3/to4e...stock motor
good luck
good luck
