Boost level will not go down? even with MBC?? help Please
Hey guys i have a question, i just got this kit installed a month and a half ago and it ran fine when i got it then all of a sudden it started boosting 10psi which it was set at 7, all of a sudden it starts boosting this amount and even with a turbo smart Manual boost controller it still is that high and it is boosting even high,what should i do?I have the manual boost controller turn almost completely off and it still boost higher even,do someone know what could be happening.Its a 94 Accord f22b1 vtec motor with full TSI turbo kit.
First off you can not lower boost with a boost controller only raise it.
Second. Is it an internal or external wastegate?
sapposed to be 7 but it was set when i got it and now it went up to 10 psi just trying to get it down is all.
gottcha, so basicly pull the boost controller out and just put another hose on it and call it good,Thanks alot much appriciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols »</TD></TR><TR><TD CLASS="quote">You can't make the boost go down any lower than what the wastegate is set at only up.</TD></TR></TABLE>
Ive been told this also and by many others.
Weird thing is.. When I first got my car boosted. With a 38mm .4bar tial and a Generic MBC spring/ball type. I could fully adjust the boost from 1psi-20ps+
Not sure why, but it did.
a1320addict
Aug 12, 2005 10:47 PM
