17 degrees low and high?
Old Oct 3, 2005 | 03:02 PM
mark_is_gay's Avatar
Default 17 degrees low and high?
tryin to figure out the timing on my motor, i figured out 17 degrees but is that on high and low cam thru out the entire rpm range? this is for a base map so i can get the car tuned. if anyone can help i would appreciate it thanks
Old Oct 3, 2005 | 03:30 PM
Default Re: 17 degrees low and high? (mark_is_gay)
bbb
Old Oct 3, 2005 | 04:23 PM
tt
Old Oct 3, 2005 | 04:33 PM
NJIN BUILDR's Avatar
This is the base ignition timing.The computer adds ignitoin timing to that for your total timing.This does not have anything to do with your cam timing.
Glenn
Old Oct 3, 2005 | 07:40 PM
Default Re: 17 degrees low and high? (NJIN BUILDR)
ahh thanks a lot my man
Old Oct 3, 2005 | 08:05 PM
so if the base timing was set at 17 degrees will the ecu set the rest? or should i put 17 degrees thru out the entire rpm range? and does anyone kno if crome has knok timing/ or sensors?
Old Oct 3, 2005 | 08:08 PM
Used2beAb16's Avatar
No you dont want timing at 17 degrees on all the maps! You just want 17 degrees for base timing.
Old Oct 3, 2005 | 08:14 PM
Default Re: 17 degrees low and high? (Used2beAb16)
ok for the base timing, then the ecu will set the rest? and do u happen to kno if crome has a knock sensor or timing ?
Old Oct 3, 2005 | 08:25 PM
2k.civic.si's Avatar
what do you need a basemap for...ill make you one so you get an idea of what its suppose to look like
Old Oct 4, 2005 | 09:19 AM
Default Re: 17 degrees low and high? (2k.civic.si)
i already got one just tryin to figure out what degree to set ignition timing at.... i need a base map so i can get my car started and tuned
RaceCarRyne
Feb 20, 2009 09:07 AM
turbo-crx
May 18, 2008 02:13 PM
Boosted Chemist
Aug 20, 2005 07:25 AM
b20z2
Aug 8, 2005 11:57 AM
wrXtian
Mar 25, 2003 03:55 PM
