how to lock timing?
Old May 18, 2008 | 08:49 AM
turbo-crx's Avatar
Default how to lock timing?
how is this done with the service connector? i need to set mine at 16*. thank you
Old May 18, 2008 | 09:01 AM
dbiker207's Avatar
Default Re: how to lock timing? (turbo-crx)
connect the terminals of the service connector with a jumper wire and set the timing with a timing light
Old May 18, 2008 | 10:38 AM
turbo-crx's Avatar
Default Re: how to lock timing? (dbiker207)
the timing is set already. i just need to lock it. thanks man. do you know if your timing isnt locked, will the car run hot?
Old May 18, 2008 | 12:02 PM
NJIN BUILDR's Avatar
The car will run high egt and won't have any power if you drive it with the timing locked.Why do you want to do this?
Old May 18, 2008 | 12:14 PM
turbo-crx's Avatar
Default Re: how to lock timing? (NJIN BUILDR)
i thought you were suppose to lock ur base timing at 16*
Old May 18, 2008 | 12:17 PM
Locking the timing with the service connector is only for setting your base timing.After that is set you disconnect the jumper and let the ecu adjust the timing as needed.
Old May 18, 2008 | 02:13 PM
turbo-crx's Avatar
thats what i meant sorry
sikek1
Apr 28, 2008 05:49 AM
civic j
Aug 17, 2007 08:10 AM
handa
Oct 24, 2004 08:27 AM
wrXtian
Mar 25, 2003 03:55 PM
