How long do wideband o2 sensors last?
Old Sep 20, 2005 | 03:25 PM
goingtobefast's Avatar
Default How long do wideband o2 sensors last?
Looking to buy a used one, with about 5k miles on it. How long do these sensors last?
Old Sep 20, 2005 | 04:05 PM
93turbo16's Avatar
mine has like 10k on it. No problems here. There is actually probably more than that on it.
Just have to put it in the right spot. like 28 inches from turbo is good.
Old Sep 20, 2005 | 04:24 PM
beepy's Avatar
Default Re: (93turbo16)
Even closer is probably okay. Many cars use WBO2 sensors stock, and rate them at 60,000 mile intervals. Just don't run race gas through them.
Old Sep 20, 2005 | 04:35 PM
Default Re: (beepy)
So 5k miles should consider really nothing for it?
Old Sep 20, 2005 | 04:55 PM
beepy's Avatar
Default Re: (goingtobefast)
As long as the former owner wasn't running race gas for that 5k miles.
Old Sep 20, 2005 | 05:06 PM
tony1's Avatar
Default Re: (beepy)
Yeah, they're usually only rated for around 50 hours on race gas.
Old Sep 20, 2005 | 05:18 PM
DaveF's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, they're usually only rated for around 50 hours on race gas. </TD></TR></TABLE>
what about alcohol?
Old Sep 20, 2005 | 08:59 PM
HiProfile's Avatar
Default Re: (Dturbocivic)
From what I know, its the lead in C16 that kills the sensors & cat. converters. I'm not really up to speed on racing gas, but I do know that gasoline can't get over 100 octane w/o lead.
In the end, if you're using racing gas, chances are you already have the $50-60 to blow on the sensors. Also, chances are that after 50 hours of running racing gas you've already blown your motor or you're running open loop right off the fuel maps.
Old Sep 20, 2005 | 09:35 PM
extrmeboost's Avatar
Default Re: (HiProfile)
yeah leaded gas will kill 02 sensors. i.e. race gas
1320king
Engine Management and Tuning
Jan 3, 2014 10:19 PM
hlub29
Jan 21, 2005 11:45 PM
B18C1CYA
Sep 7, 2004 03:27 PM
EGfastback22R
Feb 10, 2004 10:53 AM
Sh4rky
Sep 22, 2003 03:05 PM
