What Timing Belt For A B20 With A B16 Head
Old Sep 16, 2005 | 01:37 PM
gtturborex's Avatar
Default What Timing Belt For A B20 With A B16 Head
Does anyone know what timing belt to get for this application?
Thanks,
Mike
Old Sep 16, 2005 | 02:06 PM
non-VTEC's Avatar
Default Re: What Timing Belt For A B20 With A B16 Head (gtturborex)
use a B18C timing belt.
Old Sep 16, 2005 | 07:21 PM
gtturborex's Avatar
Default Re: What Timing Belt For A B20 With A B16 Head (non-VTEC)
ok, thanks
Old Sep 17, 2005 | 02:43 AM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">use a B18C timing belt.
Make sure you use a 22 tooth vtec waterpump if you use the gsr belt
Old Sep 22, 2005 | 11:48 AM
PHDZINE's Avatar
Default Re: What Timing Belt For A B20 With A B16 Head (PURPLETERROR)
If you use a b20 water pump you use a b20/b18b timing belt. If you use a gsr or b16a water pump you use a gsr timing belt.
Old Sep 22, 2005 | 06:17 PM
gtturborex's Avatar
Default Re: What Timing Belt For A B20 With A B16 Head (PHDZINE)
thanks
Old Sep 22, 2005 | 10:44 PM
White_EK49's Avatar
absolutely correctly. your water pump determine your timing belt. b16 is different.
Old Sep 23, 2005 | 04:59 AM
gtturborex's Avatar
Default Re: What Timing Belt For A B20 With A B16 Head (slow29)
that helps out a lot, guess i'll just have to ask the builder what pump he used. thanks
kevin7200
Mar 30, 2014 12:04 PM
ekturbohatch22
May 11, 2007 07:25 PM
Norcalstoppy
Aug 7, 2003 01:13 PM
Hondasaurs
Jul 30, 2003 09:12 PM
hatchii
Jun 9, 2003 10:19 PM
