Timing belt for my b20vtec?
Old Aug 6, 2003 | 01:09 AM
Norcalstoppy's Avatar
Default Timing belt for my b20vtec?
which timing belt do I need to use for my b20vtec? I'm using JDM b20b with USDM b17 head which is the same thing as 1st gen b16. PR3 head.
Also which timing belt cover would I need for my engine?
Jay Kim
Old Aug 6, 2003 | 04:03 AM
10K2HVN's Avatar
Default Re: Timing belt for my b20vtec? (AllMotorMonster+)
count the number of teeth on your water pump.
if its 22 teeth get a GSR/ITR Timing Belt.
if its 19 teeth get LS/B20 Timing Belt.
if you have 19 teeth i suggest you get a 'VTEC' 22 teeth pump with the corresponding belt.
sorry cant give you a solid answer on the Timimg Belt Cover..im still wondering that myself..but a GSR/ITR one might fit. Same deck height, same valve cover.
Old Aug 6, 2003 | 04:59 AM
sleeper4dr's Avatar
Default Re: Timing belt for my b20vtec? (10K2HVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">count the number of teeth on your water pump.
sorry cant give you a solid answer on the Timimg Belt Cover..im still wondering that myself..but a GSR/ITR one might fit. Same deck height, same valve cover.</TD></TR></TABLE>
exactly. good info. and actually if you look closely at the center of the top of the pump gear you should be able to see either a 22T or 19T which also tells you which pump you are using.
as for the timing cover, that depends on your oil pump. i've got 2 lower timing covers that i ordered and both were supposed to be ITR covers. i tried to use them with my current ITR oil pump and neither one fits correctly.
Old Aug 7, 2003 | 10:58 AM
gsrvx's Avatar
New User
jay lemme know...i have a gsr water pump.
Old Aug 7, 2003 | 01:13 PM
Default Re: Timing belt for my b20vtec? (IBspecRK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IBspecRK &raquo;</TD></TR><TR><TD CLASS="quote">jay lemme know...i have a gsr water pump.</TD></TR></TABLE>
Yay, I got a free GSR water pump. Thanks, Rod.
Jay Kim
JDMeGGaLLdAY
Aug 17, 2011 04:12 PM
faSHOwidIT
Feb 25, 2006 03:00 AM
LSVtechnologytur...
May 9, 2005 10:19 PM
infamousALLMTR
Feb 25, 2003 07:17 PM
infamousALLMTR
Feb 25, 2003 07:16 PM
