wiring d15b into 93 ex
Old Aug 27, 2005 | 02:10 PM
Kyles ej1's Avatar
Default wiring d15b into 93 ex
i have an ex so its comes with a d16z6 which is already wired for vtec and all that and it started to knock so im buying just another replacement till i can swap to b series.
can i use my stock harness for the d15b or do i have to modify it cuz its jdm or anything
and how does it work with the ecu? do i need to do anything there?
Old Aug 27, 2005 | 04:47 PM
Kyles ej1's Avatar
Default Re: wiring d15b into 93 ex (93ejay1)
bump
Old Aug 27, 2005 | 04:53 PM
A.E Motoring's Avatar
just switch over the harness, you'll be fine, pretty much the same motor
Old Aug 27, 2005 | 04:56 PM
Kyles ej1's Avatar
Default Re: wiring d15b into 93 ex (SPNFEDEJ)
so i cant just use my stock z6 harness?
Old Aug 27, 2005 | 04:57 PM
yup
Old Aug 27, 2005 | 05:45 PM
Kyles ej1's Avatar
um how come when i searched ppl say you can use your z6 harness and its plug and play and other harness's for civics like dx all you need to do is add vtec wire?
Old Aug 27, 2005 | 06:10 PM
k NM...cause the DX harness are not prewired for v tec, and the DX model dont come with v tec...so there for dx ppl need to add a couple of wires for a vtec motor
Old Aug 27, 2005 | 09:13 PM
jgalaz1's Avatar
correct, it's all plug and play if you have an EX
Old Aug 27, 2005 | 09:15 PM
handa's Avatar
Default Re: wiring d15b into 93 ex (jgalaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgalaz1 &raquo;</TD></TR><TR><TD CLASS="quote">correct, it's all plug and play if you have an EX</TD></TR></TABLE>
yup for sure.
skill178
Jun 29, 2013 06:25 AM
Slick2126
Apr 2, 2006 05:03 AM
pheen0m
Jan 17, 2005 12:57 AM
SOHC_Brian
Dec 5, 2003 09:07 AM
boostedcivicsir
16
May 9, 2003 09:58 PM
