rebuilding and cleaning a turbo
Old Aug 25, 2005 | 02:52 PM
sporty240's Avatar
Default rebuilding and cleaning a turbo
So I bought this turbo and it has shaftplay just enough to touch the blades but they werent damaged at all. So I took it apart and on the inside of the turbine there is this sand type of stuff in there covered with oil, what should I use to clean the stuff out? would engine degreaser harm anything in there?
also I need to get a rebuild kit for it where? I could not find it on their site...
its a turbonetics t3/t04E
here's some pics
Old Aug 25, 2005 | 02:55 PM
N20civicB18's Avatar
Default Re: rebuilding and cleaning a turbo (sporty240)
since your replacing all the seals and such; use brake clean
Old Aug 25, 2005 | 03:02 PM
sporty240's Avatar
Default Re: rebuilding and cleaning a turbo (N20civicB18)
how many seals are there? I only see the rubber type on the compressor side
Old Aug 25, 2005 | 10:25 PM
sporty240's Avatar
also anyone know what I should torque the compressor nut to?
Old Aug 25, 2005 | 11:11 PM
ophdehEEEzy's Avatar
The same sand-type stuff came out of my turbo when I took it apart. Im curious as to what it is as well.
Quad-Damag's Avatar
dam thats bad man
good luck
Old Aug 25, 2005 | 11:38 PM
crispydee's Avatar
Default Re: rebuilding and cleaning a turbo (Quad-Damage)
Its just carbon, nothing to worry about.
The seals are on the shaft and on the trust retainer, like a small metal piston ring. there are no rubber seals as such apart from the one you said about on the housing. Drop it all in a tub of petrol and leave it over night, should come off much easier.
Old Aug 29, 2005 | 09:18 AM
90efSI's Avatar
hey totally off topic but ive been trying to get a hold of you b/c i really want to buy your CRX! im posting it in this forum b/c im still a trial user and i cant post in the for sale forum yet. but anyways please get back to me ASAP!
-e-mailed you.
Old Aug 29, 2005 | 10:16 AM
200cs's Avatar
It looks like coked up oil. Synthetic in the future will help with that.
I would use Automatic Transmission fluid to break it loose. It has solvents in it and will probably clean it well if you soak it overnight. Good luck.
Old Aug 29, 2005 | 11:13 AM
sbiggi's Avatar
All that carbon is coked oil from a leaky seal.
I just rebuilt my turbo (to4e 50trim)
At the least you need to check the turbine shaft for straightness.
I replaced all my bearings for $90 (360 thrust kit and the full float bearings)
Cost me $65 to get the shaft strightened and another $65 to machine out the ring groove (mine was smashed and had a ding in the seat)
It wasnt hard, and do far its fine (100 miles)
-Seth
Old Aug 29, 2005 | 04:46 PM
90efSI's Avatar
hey please get back to me asap!!!
thanks
Old Aug 29, 2005 | 10:47 PM
crispydee's Avatar
Default Re: (90efSI)
Just PM him!
Old Aug 29, 2005 | 10:57 PM
Cray91's Avatar
If you are gonna spend the time/money on a rebuild then get it balanced also. Just adding to the life of your turbo.
Old Sep 4, 2005 | 05:11 PM
sporty240's Avatar
Default Re: (Cray91)
anyone know what internals turbonetics uses? I heard garett?
Old Sep 6, 2005 | 12:48 AM
sporty240's Avatar
Default Re: (sporty240)
any1
Old Sep 6, 2005 | 04:31 AM
igy's Avatar
igy
Yes, Garrett.
Old Dec 10, 2005 | 10:25 PM
supercreed2002's Avatar
Default Re: (igy)
I also see a t04e in my future...57 trim. I like to know what the nut should be torqued to? Also, any good rebuild write-up with picture for this turbo specifically?
s52b32
Oct 5, 2007 08:57 PM
curt801
Feb 8, 2007 06:18 PM
SPOOLINmatt
Jan 28, 2005 06:48 PM
FuzzyGreen
Sep 3, 2003 08:23 AM
Vtec92Civic
Jul 8, 2003 11:33 PM
