DYNO results @ 8psi
Old Aug 24, 2005 | 08:40 PM
boosted k20's Avatar
Default DYNO results @ 8psi
just got done tuning a built LS/VTEC motor (on 84 mm sleeves). i couldnt get the damn 3-bar to work on uberdata so i tuned it on the stock mapsensor at only 8psi. the car put down 308whp at only 8 psi. i was impressed, i thought it was only gonna be making like 275whp, but the 308whp suprised me. the curve was nice and smooth, no peakiness or sudden drops, just constant power.
Overall timing at 8psi was around 22.5* and had an a/f of 11.4-11.7
Old Aug 24, 2005 | 08:52 PM
vaporboy12's Avatar
Default Re: DYNO results @ 8psi (boosted k20)
good numbers get the 3 bar hooked up and write and crank that **** up
Old Aug 24, 2005 | 09:18 PM
turbo_ef9's Avatar
Default Re: DYNO results @ 8psi (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote"> good numbers get the 3 bar hooked up and write and crank that **** up</TD></TR></TABLE>
Old Aug 24, 2005 | 09:48 PM
racinskittle's Avatar
Damn!! Nice. Good to hear someone pleasantly surprised by their numbers
Old Aug 24, 2005 | 09:56 PM
AspectIndustries's Avatar
Default Re: DYNO results @ 8psi (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">Damn!! Nice. Good to hear someone pleasantly surprised by their numbers </TD></TR></TABLE> Fosho!
After 1 year of boosting, I still havent dyno my car yet. Maybe Id be in for a suprise too?
Old Aug 24, 2005 | 09:57 PM
steelies's Avatar
PM adesguy if you need help setting up the GM 3bar stuff. He's got alot of info from what I've read in his posts about using it w/ uber
great numbers by the way
Old Aug 25, 2005 | 05:41 AM
Default Re: DYNO results @ 8psi (steelies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steelies &raquo;</TD></TR><TR><TD CLASS="quote">PM adesguy if you need help setting up the GM 3bar stuff. He's got alot of info from what I've read in his posts about using it w/ uber
great numbers by the way</TD></TR></TABLE>
i followed his write up on how to use the 3-bar in the uberdata website but i still didnt have no luck. i tried to wire in the 3-bar all possible ways (thinking that my wiring was wrong), used two different 3-bars: a GM 3-bar and a MSD 3bar. still got nothing. the car would startup on the basemap i made for the 3bar, but it would only stay in one vacuum pressure, it would not change no matter if the vacuum pressure changes. me=stumped!
with the way this car is making power with boost, getting over 500whp outta this thing on around 20psi should be a peice of cake
Old Aug 26, 2005 | 06:13 AM
finally got the 3-bar up and running! now time to retune and see if we can hit the 500whp mark on uberdata!
dirt_06
Honda S2000
24
Jun 11, 2006 12:54 AM
blackeg
Mar 13, 2006 03:14 PM
D-tuned
Nov 11, 2004 07:28 PM
gstintegra92
Feb 7, 2004 07:39 AM
accordfreak
Dec 14, 2003 12:06 AM
