ARP Stud Lubricant Application
Old Aug 17, 2005 | 08:33 AM
LSEGHATCH's Avatar
Default ARP Stud Lubricant Application
For those of you that used the ARP Lube that comes with head studs, did you use the lube for puting the studs into the block, bolts onto studs, or both?
Old Aug 17, 2005 | 09:09 AM
xyzalvarez's Avatar
Default Re: ARP Stud Lubricant Application (LSEGHATCH)
I used AEBS studs and aplied just regular motor oil to "all"
studs into block, bolt into studs....
Old Aug 17, 2005 | 09:30 AM
LSEGHATCH's Avatar
Default Re: ARP Stud Lubricant Application (xyzalvarez)
Well all but one stud are in the block. The stud on left intake side doesn't want to go all the way down for some reason, should I clean it out with a tap?
Old Aug 19, 2005 | 02:58 AM
efstile's Avatar
thats your best bet.
Old Aug 19, 2005 | 10:53 AM
msmotorsports's Avatar
Use the assembly lube in both the block and bolts to get proper torque specs. Never put in dry.
phelpsj2
Feb 13, 2012 03:26 PM
jaron_cc
Apr 3, 2009 07:33 PM
kuja396
28
Aug 1, 2008 10:25 AM
totsie7944
Feb 20, 2008 07:27 PM
flip1199
Aug 2, 2005 12:28 PM
