car runs like shit (compression results inside)
#1 200 #2 190 #3 205 #4 #205.. i have 10:1 pistons, car has been overheating during daytime hot weather with a/c on, only thing left to replace as far as cooling goes is radiator but i'm unsure if that will do anything, theres no coolant loss, no smoke, not burning oil or anything..
my 1/4 mph is off by 8-10mph, the car is clearly at least a second slower than it was, even during night when it does not overheat, it still feels like it hesitates when accelerate, it will still boost and pull, its just doesn't haul like you would expect with turbo..
earlier today i tried to downshift to wot, and it woudln't just go, i tried twice and it woudln't go past ~4k rpm.. rotor/cap/plugs have few thousand miles on it.. all honda oem ignition.
any ideas? i have the right fuel setup, intank fuel pump, large injectors, hondata and tuned.. ran just fine for 2 years and now this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">spooling late?
oil in charge pipes?</TD></TR></TABLE>
spooling is fine, and no theres no oil.. i don't think its turbo.. my afr showing rich, and plugs didn't look like it was running lean
would cooling system pressure check be sufficient enough? or i need to do a leakdown as well? and anybody got a way to explain why the car woudln't rev up after i downshifted that one time?
both fans work and blow the right direction, a/c fan blades are melted (that may possibly explain overheat and i'm going to replace the blades).. but i can't understand why my car hesitates at wot, even when in partial throttle, its not all that smooth as it used to be
Do a leak down test first to ensure the motor is still healthy. As far as overheating and poor performance, you might have 2 separate problems. Only thing to do would be troubleshoot them 1 at a time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c »</TD></TR><TR><TD CLASS="quote">Do a leak down test first to ensure the motor is still healthy. As far as overheating and poor performance, you might have 2 separate problems. Only thing to do would be troubleshoot them 1 at a time. </TD></TR></TABLE>
an update, i think i took care of overheating problem.
1. replaced melted condenser fan
2. there was an exhaust leak where dumptube connects to wastegate
so it hasn't been overheating.. it runs a bit better, but still not as strong like it used to be, i'm gonna pull the cat next to see if its clogged..
eg2wes
Dec 25, 2005 05:11 PM
sleepereg
Jun 21, 2004 10:13 PM
SOFLSOL
Mar 2, 2004 10:26 AM
BodyKits NW
Oct 8, 2003 08:13 AM
