HELP: Turbo leaking oil
HAVE my turbo is leaking oil i have a picture attached and it is leaking on all 4 sides where i have an arrow, i think it is leaking right through the bolts, any one know why or what i can do
http://www.we-todd-did-racing....x.jpg
i can post more pics if neccesary
i have 3 out of 4 factory bolts, they were on i just took on off in the picture, is there supposed to be like teflon tape on them or something
Those bolts hold the back plate onto the CHRA.
All 4 of them need to be there and torqued down properly in order to put pressure on the compressor seal. If you are missing a bolt or they are not torqued properly the compressor seal will not seal properly and it could cause it to leak.
I would try getting another bolt and tightening them all down. Then if it still leaks you might need a rebuild.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">if u want u can weld them shut</TD></TR></TABLE>
LoL... yeah, give that a try and see if it works.... Hahaha.
i do have the 4th bolt, i just took it off in the pic, do you need like teflon tape around it, and how many pounds do u torqe it down,
There's a link to the torque specs in this thread...
https://honda-tech.com/zerothread?id=1298985
Something like 8ft/lbs
