Turbo Oil Feed Postion ?
Ok ive been trying to clock my turbo for bouth 3 1/2 hrs now. ive heated it. Smacked it with a rubber mallet...will it was heated and held in a vice.. to make a long story short..it wont budge...sooo i have a little question...
The feed isnt right on top like its suposed to be...but its kinda ...on the top lol...no pictures im sorry. Im wondering if the oil pressure from the motor will push the oil enough where it will flow out.? Is there enough pressure there. Or do i have to put it on top.? i Would say that it would be at a 10:00 postion...can someone help me out with this....
Re: Turbo Oil Feed Postion ? (99Sivic)
how is it so hard to more that you need a torch and hammer to clock the turbo?
are you sure you loosend the correct bolts? it should spin super easy with the bolts loose.
what kind of turbo is it? is it new or used?
Re: Turbo Oil Feed Postion ? (non-VTEC)
its a T3 super 60... the inlet turbine spun fine..but for the exhaust housing it didnt move..i had losend all the bolts that are on the exhuast housing....Its a used turbo.
Eveyone says that its easy, and im not super retarted.... but if its not moving. its not moving....
Re: Turbo Oil Feed Postion ? (wantboost)
Yah i thought that it would be like eveyone said....just get some heat on it. and it will turn fine...NOPE ..sorry.. There are 6 bolts on the exhaust side. Losend all of them. Now the 4 bolts that are in the middel where the oil and water feeds are. do those need to be taken out?.
Who is Mr Robot?
no, if you pull those out you are taking the whole compressor side off of the turbo, of course it wont come off because the compressor wheel is still bolted on the shaft,
what would be better for heat is if you have an oxyacetelene torch and youcould just adjust it to a sooty flame.
well we had one at my buddies garge but i dont know who to work that. and i dont wanna blow my self up. LOL i had just a propane one that i had in my garage but it was really freaking hot.
Do you think i could take it to a muffler shop?.... Think they might be able to handel that. Even thou most of them are hill-jacks here.
hit that exhaust housing hard and evenly on each side, hit it at four different end like a diamond shape, Hit that shiet very hard and put alot of pb blaster, I had to hit the crap out of mines. When u think u are hitting hard, hit harder
Re: Turbo Oil Feed Postion ? (oxSLEEPERxo)
LOL that just sounds scary.. haha soo PB would help huh... well i guess i soak the crap outta the thing and try it again. Gotta run to wally word to get some PB
well i finally got it to turn..but i had to put some liquid n20 to the center portion of the turbo...then heat the exhaust houseing....then it moved like it was nothing....
