vtech cylinoid kicking on an off
Old Aug 12, 2005 | 11:48 AM
QUIKRLS's Avatar
Default vtech cylinoid kicking on an off
vtech cylinoid kicking on and off at 5000 rpm, it wont rev past 5000 rpm in second gear half the time, help!
Old Aug 13, 2005 | 08:15 AM
QUIKRLS's Avatar
Default Re: vtech cylinoid kicking on an off (WHTGEN2)
bump
Old Aug 14, 2005 | 02:49 AM
eg6T's Avatar
buy a new phone battery
Old Aug 14, 2005 | 03:50 AM
JDMtype Eg6's Avatar
Default Re: vtech cylinoid kicking on an off (eg6T)
hahaha
Old Aug 14, 2005 | 04:56 PM
QUIKRLS's Avatar
Default Re: vtec cylinoid kicking on an off (JDMtype Eg6)
oops, sorry for the mispell
Old Aug 14, 2005 | 08:05 PM
cchhrriiiss's Avatar
Default Re: vtec cylinoid kicking on an off (WHTGEN2)
eg6T..your a ******* ********.....
Check your oil man. Is it up to level? Selinoid could be going bad.
Old Aug 14, 2005 | 08:37 PM
are you throwing any codes? the cause of not revving past 5k could also be a ignition or fuel problem.. Also you should try to check all your vacuum hoses.
Old Aug 15, 2005 | 08:18 AM
QUIKRLS's Avatar
Default Re: vtech cylinoid kicking on an off (JDMtype Eg6)
I havnt checked the computer yet, i have not had the chance to hook up the o2 sensor or i think its the oil pressure switch, im using obd0 computer, do i have to get a computer from a vtec car?
Old Aug 15, 2005 | 08:19 AM
QUIKRLS's Avatar
Default Re: vtec cylinoid kicking on an off (ChrisColeman)
oil level is good so far
Old Aug 15, 2005 | 01:22 PM
steveobb4's Avatar
Check the pressure switch for continuity.
Old Aug 16, 2005 | 12:35 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHTGEN2 &raquo;</TD></TR><TR><TD CLASS="quote">I havnt checked the computer yet, i have not had the chance to hook up the o2 sensor or i think its the oil pressure switch, im using obd0 computer, do i have to get a computer from a vtec car?</TD></TR></TABLE>
First off, you shouldn't drive your car again until you hook up an o2 sensor. Next, you need a vtec ecu for vtec to work, may i suggest the correct ecu for whatever engine you have, as the fuel and ignition maps are pretty damn important too. I have a feeling it'll be a while before you get it running right...
Old Aug 16, 2005 | 09:49 PM
j87w's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">buy a new phone battery</TD></TR></TABLE>
Thats Great!
RIPTEC
Jul 9, 2013 10:18 PM
Mike Makovsky
Honda Civic (2001 - 2005)
10
Feb 20, 2013 09:07 AM
Snail Tuning
Oct 21, 2004 08:16 PM
mugenhatch92
Jul 31, 2004 05:23 PM
SpeedingHatch
May 14, 2004 08:30 AM
