VSS + Code 17 = no vtec..
Old Aug 9, 2005 | 07:13 PM
JDM_SOHC's Avatar
Default VSS + Code 17 = no vtec..
my vss went out i believe, and what leads me to this conclusion is my CEL throwin a 17, but thats not what im wondering... what im wondering is, how can the Speed Sensor have anything to do that would affect the way VTEC works...?? Vtec i thought got its information from the computer..?? Is it cuz if the Speed Sensor doesnt work, ur car doesnt know how fast ur going, therefore vtec doesnt know when to kick in..?? I'm replacing it tomorrow so it should all work by then, but also I was wondering if anyone knows what sensor is it thats directly under the distributor on the JDM SOHC motors that screws into the tranny..?? Thanks..
Old Nov 8, 2005 | 08:20 AM
phukaduck's Avatar
Default Re: VSS + Code 17 = no vtec.. (JDM_SOHC)
VTEC ONLY OPERATES IF 4 CONDITIONS ARE MET.
ENGINE TEMPERATURE HAS TO BE UP TO RUNNING TEMPERATURE
THE OIL PRESSURE HAS TO BE AT THE RIGHT PRESSURE
THE RPM'S HAVE TO BE AT THE CORRECT RPM
AND THE SPEED OF THE VEHICLE HAS TO BE ABOVE SOMETHING LIKE 30 km/h OR 20mph
SO YEAH... THE VSS NEEDS TO BE FIXED BEFORE VTEC WILL WORK. I NEED TO FIX MY VSS BUT I'M HAVING NO LUCK. I'VE ORDERED A NEW ONE FROM HONDA.. I'LL FOLLOW UP TO TELL IF IT WORKED OR NOT.
stehigs321
15
Mar 1, 2019 05:16 PM
kaboom954
Feb 25, 2010 03:23 PM
1PT-SICK
Apr 22, 2006 02:15 PM
civicseth
16
May 18, 2005 08:51 PM
E36 Guy
Dec 11, 2003 03:15 PM
