550WHP on stock ports and valves???
I did a search!!
My next setup im going for 550 wheel horse and was wondering with my setup, do u think it could be done with basically a stock GSR head?
IM planning on doing valve springs and cams that alow me to rev to about 9500RPM. but i dont want to invest in actual head work.Im doing it to almost prove a point but saving the cash is also a factor.Ive seen it done a bunch of times, but i just want to get some opinions, and maybe some examples of HP gains when porting is applied.
Also, is a simple catch can enough ventalation for this much power? I see alot of people tapping 2 fittings into thier valve covers and was wondering if this is nesscary, or can I just stick w. my old catch can system.
The setup
Fully built LS/vtec with 9-1 CR and 84mm bore.Stock LS crank and main caps.
GT35R .82A/R
Full Race Style Ramhorn mani with wastegate in front
A big backdoor IC
Hondata
and all the other essentials.
I know its a vague question but gimme some help guys.Thanks
The setup
GT35R .82A/R
A big backdoor IC
Hondata
Thats one of my concerns.Ill do what ever it takes to reach that mark though.
What cams could i use to get a good long power band w/ this big of turbo.
Its going to be a street/track car so I want to have a broad power band instead of peak power
stock GSR cams wont let me use the full potential of this trubo.I want this thing to rev high but still retain a broad power range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">a set of ITR cams will work really well also.....
with cam gears too yOOO
</TD></TR></TABLE>with cam gears too yOOO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">488whp on gsr cams right here rev to 9800</TD></TR></TABLE>
i bet with itr cams and gears you can gain an easy 50whp, or get the same horsepower with less boost
When I was on stock head, St00pid made 680 Whp with 520 Ft/lb on a T3 (GT3767S). All we have was springs and retainers. Granted we were in the upward of 40 psi ish, but we made it there...
stan
stan
ludesleep
Jun 12, 2003 06:25 AM
