500hp ls setup? (valve springs?)
Old 02-04-2004, 05:34 PM
MIDNIGHT's Avatar
Default 500hp ls setup? (valve springs?)
here is the set up so far
98 ls block with aebs sleeves
stock polished crank
eagle rods with upgraded bolts/ je 9.0:1 pistons
stock head
stock cams with skunk2 cam gears
jg intake manifold and 68mm t/b
4 1000cc rc injectors
turbosmart 40mm wastgate
equalength manifold(turboperformance)
3" exhaust
large front mount size yet to be known
2.5 i//c piping
60-1 t3/t4 .48 ar
hondata s200
for my 500hp goal will i need to upgrade the valve springs and valves?
and do ya see any problems with the setup?
stock cams
Old 02-04-2004, 06:36 PM
Sprayteg's Avatar
Default Re: 500hp ls setup? (MIDNIGHT)
I think .48ar wil be to small for your goal. Beside this, to achieve that kind of power, i would go with cams/springs and more rpm that the stock rev limit. Porting the head will help a lot too.
Einhander276
08-31-2012 11:41 AM
nvrl8
04-28-2009 09:28 PM
pythoner
09-29-2007 03:45 PM
4drDA
04-26-2006 05:07 PM
420aNT
12-10-2002 11:12 AM
Quick Reply: 500hp ls setup? (valve springs?)
