Vtec oil pressure switch defective or unpluged code...
Old Aug 7, 2005 | 09:58 AM
drudy's Avatar
Default Vtec oil pressure switch defective or unpluged code...
My cel popped on the other day and i checked the code and it was code 22 vtec oil pressure switch defective or unplugged/ defective oil pressure switch. Im pretty sure vtec hadnt been engaging before the light came on. Is this a fixable problem or do i have to replace the whole solinoid?
Old Aug 8, 2005 | 08:10 AM
JimBlake's Avatar
Default Re: Vtec oil pressure switch defective or unpluged code... (drudy)
The VTEC oil pressure switch isn't the same thing as the VTEC solenoid. You should be able to get just the switch.
But first, make sure that's the problem. It could be unplugged. Or check for a broken wire or something like that. Then make sure your oil's OK, because if your overall oil pressure or inventory is low, it should throw the same code.
Old Aug 8, 2005 | 02:39 PM
Chiovnidca's Avatar
Default Re: Vtec oil pressure switch defective or unpluged code... (JimBlake)
The first thing I check is the oil level.
Old Aug 8, 2005 | 03:06 PM
rainforest's Avatar
Default Re: Vtec oil pressure switch defective or unpluged code... (Chiovnidca)
check for continuity at the oil pressure switch. second check for continuty from the blk/yel wire on the harness to d6 on the ecu. also check the oil like your buddy said. also check the vtec screen for obstructions and plunger between the selanoid and the vtec assembly.
Old Aug 8, 2005 | 06:23 PM
drudy's Avatar
Default Re: Vtec oil pressure switch defective or unpluged code... (rainforest)
thanx guys will do that asap.
Old Aug 16, 2005 | 02:58 PM
drudy's Avatar
I checked continuity and had 1.6 or 1.7 ohms at the switch. The screens were clear and plunger worked fine. I was wondering if it could be not making enough oil pressure possibly, or would that throw a different code?
Old Aug 16, 2005 | 06:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drudy &raquo;</TD></TR><TR><TD CLASS="quote">I checked continuity and had 1.6 or 1.7 ohms at the switch. </TD></TR></TABLE>
That's probably the problem.
Old Aug 17, 2005 | 05:29 PM
drudy's Avatar
what should it be?
Old Aug 26, 2005 | 11:59 AM
drudy's Avatar
I put a new switch in and fixed a few of the wires, but still no go on fixing it. It still throws a code 22. The oil level is fine. Do you think low overall oil pressure would throw this code or would it b a different code?
Old Aug 26, 2005 | 12:20 PM
R-Toyz.com's Avatar
check your wires from the vtec solenoid to the ECU...there may be a short in between.
missionaryrider
Dec 9, 2007 01:50 AM
hellogsr
Oct 11, 2006 09:29 AM
drudy
Aug 7, 2005 05:59 AM
allnapower
Apr 1, 2005 08:22 AM
BeeResp0nsible
Nov 29, 2002 05:43 AM
