throwing vtec pressure switch ecu code
Old Oct 8, 2006 | 01:01 PM
hellogsr's Avatar
Default throwing vtec pressure switch ecu code
on my way to work this morning my check engine light came on. throwing 22. ive looked it up and ive gotten both vtec pressure switch and oil pressure switch as this error. which is it or are they the same thing? does anyone know how i can fix this? also, last night i was kinda gettin on it and it would hesitate around 7k...if that helps at all. its a 2000 gsr with only 65,xxx miles - bone stock. any help at all guys is much appreciated.
Old Oct 8, 2006 | 02:05 PM
one bad dx's Avatar
Default Re: throwing vtec pressure switch ecu code (hellogsr)
Check your oil level, if you havent changed your oil recently do so. Is Vtec engauging still?
Old Oct 8, 2006 | 02:39 PM
hellogsr's Avatar
Default Re: throwing vtec pressure switch ecu code (one bad dx)
vtec still pulls along with the butterflies at 6..it just kinda hesitates around 7..but ill check the oil, thanks
Old Oct 8, 2006 | 03:19 PM
one bad dx's Avatar
No problem, you may have to bleed your vtec soleniod as well. Sometimes you get a burp or a air pocket in there that can cause the same thing.
Old Oct 8, 2006 | 08:03 PM
hellogsr's Avatar
Old Oct 8, 2006 | 09:55 PM
pman44's Avatar
these are 2 independent switches, both telling you that your oil pressure is low. i'd get the problem figured out before driving the car. test the pressure with a gauge connected where the oem pressure switch goes.
make sure your oil and filter are fresh. check your pan for dents that may be blocking oil flow to the pickup.
Old Oct 9, 2006 | 08:50 AM
one bad dx's Avatar
Default Re: throwing vtec pressure switch ecu code (pman44)
If you would like a more detailed explanation of bleeding the solenoid send me a PM and I'll do my best to walk you through it. I've only done it about a thousand times now haha. I should have just saved it in my notes lol.
Old Oct 10, 2006 | 10:24 AM
hellogsr's Avatar
top
Old Oct 10, 2006 | 11:05 AM
CHONCH2's Avatar
bleed your vtec solenoid, that should fix it
Old Oct 11, 2006 | 09:29 AM
hellogsr's Avatar
Default Re: (CHONCH2)
how do you bleed the vtec solenoid?
barone
25
Aug 20, 2009 08:32 AM
missionaryrider
Dec 9, 2007 01:50 AM
drudy
Aug 26, 2005 12:20 PM
allnapower
Apr 1, 2005 08:22 AM
b18c-93
Jan 7, 2002 09:25 PM
