My New Turbo setup. On a budget
Old Aug 3, 2005 | 06:30 PM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
Default My New Turbo setup. On a budget
Fresh Engine Rebuild:
BLOCK:
Je pistons .20 over low comp 9.0-1
eagle forged H beam rods
eagle forged crank (mine was fucked from a spun rod bearing)
new oil pan and pickup (oem)
stage 3 clutchmasters clutch
Fidanza lightweight flywheel
ARP head studs
ARP main studs
FULL Honda Gasket Sets
HEAD:
NGK plug wires
NGK spark plugs
ferrea valves (turbo)
skunk2 turbo cams
skunk2 valve springs
skunk2 titan. retainers
AEM tru time cam gears
AEM Short Ram Intake
Turbo:
T3/T04E 57 .63 a/r
Rev-Hard Manifold
2.5" Downpipe
3" Catback exhaust stock muffler
Tial 38mm Wastegate
Tial 50mm BOV
Rev Hard Intercooler 28x6.5x3
Fuel Management:
Hondata s200 setup
AEM fuel rail
AEM fuel filter
Aeromotive fuel P.R.
Walbro 255 HP Pump
OTHER
AEM underdrive pully's
lightweight crank pully
Yellow Top Battery
anything you can reccomend to my my system better? im only going for 350-400hp and this in a full interior 1995 integra in case you were curious.
Old Aug 3, 2005 | 07:25 PM
hondaimport99's Avatar
Default Re: My New Turbo setup. On a budget (Project Evo Crusher)
Wow, your gonna have a AEM short ram intake on top of having a turbo set-up...Thats amazing Should make some crazy power...........
Old Aug 3, 2005 | 07:56 PM
DC2tuner's Avatar
Default Re: My New Turbo setup. On a budget (hondaimport99)
thanks for the compliment
Old Aug 3, 2005 | 07:58 PM
wantboost's Avatar
Who is Mr Robot?
dont forget to get a line bore once the mainstuds are installed... tack on another 220 bucks at least for that
Old Aug 3, 2005 | 08:22 PM
DC2tuner's Avatar
Default Re: My New Turbo setup. On a budget (wantboost)
did that
Old Aug 3, 2005 | 08:28 PM
Adi Radoncic's Avatar
On Fire!
get rid of the main studs on your list and just get stock bolts... studs are a waise of money.. in your "budget setup".
I don't see injectors on your list.
Take the fuel rail off from the list, and the aem fuel filter.
The pully kits are bs you don't need that just a waiste of money again, and keep your factory crank pulley.
The flywheel is ok but not really needed. The stock one would do a fine job aswell.. again a money thing..
PrecisionH23a's Avatar
i would ditch the s2 valvetrain and cams if your on a budget. i would also go with a larger trim turbo if you want 400whp.... at least a60 on the comp. the .63 ar is good.... staged wheel by any chance?
you also forgot to tell us what engine your running.
Old Aug 3, 2005 | 08:34 PM
Mag00n's Avatar
Default Re: My New Turbo setup. On a budget (PrecisionH23a)
On a budget? GTFO
Old Aug 3, 2005 | 08:49 PM
DC2tuner's Avatar
Default Re: My New Turbo setup. On a budget (Mag00n)
well everything listed is paid for by minimum wage work at good ol' Chuck E. Cheese. the only parts of my setup not purchased yet are the turbo parts. so on a budget i meant im lucky if i bring in a $1000 bux a month. so i didnt want people to start sugesting parts way out of my reach.
Old Aug 3, 2005 | 09:19 PM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaimport99 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, your gonna have a AEM short ram intake on top of having a turbo set-up...Thats amazing Should make some crazy power...........</TD></TR></TABLE>
lol he was being sarcastic...
How much have you spent cause them goodies don't come cheap...
Old Aug 4, 2005 | 02:59 PM
DC2tuner's Avatar
Default Re: My New Turbo setup. On a budget (Redwidow)
i know he was being sarcastic thats why i put a
well ive been pretty much putting all my money into my car so it has taken quite a while to get where im at.
Old Aug 4, 2005 | 03:54 PM
donkiman's Avatar
how light is your flywheel?
Old Aug 4, 2005 | 04:15 PM
DC2tuner's Avatar
Default Re: My New Turbo setup. On a budget (donkiman)
9 lbs.
DC2tuner
Oct 23, 2004 07:16 AM
dc2_tuner
Sep 6, 2004 03:41 PM
dc2_tuner
Sep 4, 2004 06:37 PM
dc2_tuner
Sep 4, 2004 06:35 PM
dc2_tuner
Aug 30, 2004 03:13 PM
